Summary: nvidia laptop with 2 external displays, intel mesa driver is loading instead of nvidia which means that the display plugged directly into the nvidia card is displaying only the mouse, nothing else.
Sometimes I can get the nvidia driver to load properly if I reboot the laptop, but many times I can do this 10 times and only the 11th time will work.
- GPU: NVIDIA RTX 2000 Ada Generation Laptop GPU
- Nvidia driver version: 575.64.03
- Nvml version: 12.575.64.03
- OS: Ubuntu 22.04.5 LTS
- Kernel version: 6.8.0-65-generic
- PC setup: Internal display, 1x DP external display, 1x external HDMI display
What I tried:
- Completely wipe and reinstall the driver many times. Each case, the first startup is OK. Next startup is starting to act up.
- Install different versions of nvidia driver combined with different kernel version
- Start the laptop with only one display attached
- Play around with xorg config files, I can’t tell you exactly what I did because many times I followed suggestions found on the internet, but nothing worked that lasted
Nvidia bug report: nvidia-bug-report.log.gz (398.1 KB)
