Hi all,
I want to ask, what is the latest CUDA version and driver that supports the Nvidia M60?
According to the driver search side from Nvidia (link)
it should be CUDA 12.6 with the driver 560.35.03 for OpenSUSE 15, but that is not working on my side.
thanks in advance
M60 is SM5.2 and as you say, should be supported on both driver and toolkit.
What do you mean by “not working”?
after installation from cuda 12.6 and driver 560.35.03
nvidia-smi response with
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Output from “lspci -v”:
03:00.0 VGA compatible controller: NVIDIA Corporation GM204GL [Tesla M60] (rev a1) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation Device 115e
Flags: fast devsel, IRQ 32
Memory at f5000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [258] L1 PM Substates
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] #19
Kernel modules: nouveau, nvidia_drm, nvidia
04:00.0 VGA compatible controller: NVIDIA Corporation GM204GL [Tesla M60] (rev a1) (prog-if 00 [VGA controller])
Memory at f4000000 (32-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d0000000 (64-bit, prefetchable) [size=32M]
I/O ports at d000 [size=128]
i also found this in the “dmesg” output:
[ 5.116608] nvidia: loading out-of-tree module taints kernel.
[ 5.116623] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 5.228720] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 5.229833] nvidia 0000:03:00.0: enabling device (0000 -> 0003)
[ 5.229940] nvidia 0000:03:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[ 5.229967] NVRM: The NVIDIA GPU 0000:03:00.0 (PCI ID: 10de:13f2)
NVRM: installed in this system is not supported by open
NVRM: nvidia.ko because it does not include the required GPU
NVRM: System Processor (GSP).
NVRM: Please see the 'Open Linux Kernel Modules' and 'GSP
NVRM: Firmware' sections in the driver README, available on
NVRM: the Linux graphics driver download page at
NVRM: www.nvidia.com.
I think this is your problem - using the open driver. Older cards aren’t supported, see here.
thanks, that was the solution, switch from open to proprietary driver:
sudo zypper remove nvidia-open-driver-G06-kmp-default
sudo zypper install --details cuda-drivers
