This Guide is based on http://duxyng.wordpress.com/2012/01/26/finally-working-nvidia-optimus-on-fedora-16/
First install akmod-nvidia from rpmfusion.
yum install kmod-nvidia
Remove following files installed by nvidia-driver
rm /etc/X11/xorg.conf
rm /etc/X11/xorg.conf.d/00-nvidia.conf
rm /etc/ld.so.conf.d/nvidia-lib64.conf
Move nvidia extensions away from xorg standard path
mv /usr/lib64/xorg/modules/extensions/nvidia/ /usr/lib64/nvidia-bumblebee/
Now download and install bbswitch
https://github.com/Bumblebee-Project/bbswitch/downloads
yum install dkms
tar xvzf bbswitch-0.4.1.tar.gz
sudo cp -Rv bbswitch-0.4.1 /usr/src
sudo dkms add -m bbswitch -v 0.4.1
sudo dkms build -m bbswitch -v 0.4.1
sudo dkms install -m bbswitch -v 0.4.1
Next install Bumblebee
https://github.com/Bumblebee-Project/Bumblebee/downloads
tar xvzf bumblebee-3.0.tar.gz
cd bumblebee-3.0
./configure --prefix=/usr --sysconfdir=/etc
make
sudo make install
sudo cp scripts/systemd/bumblebeed.service /lib/systemd/system
Now configure bumblebee
Edit /lib/systemd/system/bumblebeed.service line 7 to read:
ExecStart=/usr/sbin/bumblebeed --config /etc/bumblebee/bumblebee.conf
Edit /etc/bumblebee/bumblebee.conf and change:
Driver=nvidia
and in section [driver-nvidia]:
KernelDriver=nvidia
LibraryPath=/usr/lib64/nvidia
Edit /etc/bumblebee/xorg.conf.nvidia and insert at the beginning:
Section "Files"
ModulePath "/usr/lib64/nvidia-bumblebee/nvidia/"
ModulePath "/usr/lib64/xorg/modules"
EndSection
and appand at the end
Section "Screen"
Identifier "Screen1"
Device "Device1"
EndSection
Now install CUDA as described here
http://reset.etsii.upm.es/en/users/peque/installing-cuda-in-fedora-16/
