Nvidia-powerd.service fails to start
On my PC, nvidia-powerd.service is failing to start.
Typing in “systemctl status nvidia-powerd” outputs "found unsupported configuration. Exiting… "
I use a GTX 1050 with an I7-4790.
nvidia-driver-555 is installed.
I am using two monitors.
Ubuntu 22.04 (Pop-os)
Full output of systemctl status nvidia-powerd
× nvidia-powerd.service - nvidia-powerd service
Loaded: loaded (/lib/systemd/system/nvidia-powerd.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2024-08-28 16:16:19 CEST; 4min 50s ago
Process: 873 ExecStart=/usr/bin/nvidia-powerd (code=exited, status=1/FAILURE)
Main PID: 873 (code=exited, status=1/FAILURE)
CPU: 3ms
Aug 28 16:16:18 pop-os systemd[1]: Started nvidia-powerd service.
Aug 28 16:16:18 pop-os /usr/bin/nvidia-powerd[873]: nvidia-powerd version:1.0(build 1)
Aug 28 16:16:19 pop-os /usr/bin/nvidia-powerd[873]: Found unsupported configuration. Exiting…
Aug 28 16:16:19 pop-os systemd[1]: nvidia-powerd.service: Main process exited, code=exited, status=1/FAILURE
Aug 28 16:16:19 pop-os systemd[1]: nvidia-powerd.service: Failed with result ‘exit-code’.
As you probably know, nvidia-powerd is for dynamic boost feature. Unfortunately, your GPU (GTX 1050) isn’t supported.
See here:
Dynamic Boost is supported only on platforms that meet all of the following requirements:
  1. Notebook form factor.
  2. Ampere or newer GPUs.
  3. Intel CometLake or newer Intel chipsets, or AMD Renoir, Cezanne, Rembrandt, or newer AMD chipsets.
  4. SBIOS support for Dynamic Boost
    Run the following command to check if the SBIOS supports Dynamic Boost:
    nvidia-settings -q DynamicBoostSupport
