I have a new DELL G15 Laptop with GeForce RTX 4060. vvcaI installed Ubuntu 20.04 and tried to install the NVIDIA driver using “sudo ubuntu-drivers install”. After the installation, I rebooted and ran nvidia-smi and got an error
“NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure the latest NVIDIA driver is installed and running”.
I have upgraded the kernel to latest 6.8.4 as well. My HDMI, MIC and other IOs (Connected to Graphic card) are also not working.
@generix Could you please help. Below are some of the results.
dell@ptdell:~$ sudo prime-select query
nvidia
dell@ptdell:~$ dkms status
nvidia, 535.161.07: added
dell@ptdell:~$ grep -r nvidia /etc/modprobe.d/* /lib/modprobe.d/*
/etc/modprobe.d/blacklist-framebuffer.conf:blacklist nvidiafb
/lib/modprobe.d/nvidia-kms.conf:# This file was generated by nvidia-prime
/lib/modprobe.d/nvidia-kms.conf:options nvidia-drm modeset=1
dell@ptdell:~$ uname -a
Linux ptdell 6.8.4-060804-generic #202404041833 SMP PREEMPT_DYNAMIC Thu Apr 4 18:46:22 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
My Main OS is ubuntu 20.04 LTS, however I have updated my kernel to 6.8.4 as the default kernel 5.15 is not working with 4060 RTX. Please refer the attached nvidia bug report. nvidia-bug-report.log.gz (132.2 KB)
The mainline kernel will not work with Ubuntu 20.04.
Best would be to update to a newer Ubuntu version.
If not possible (as liquorix also dropped 20.04), the only place I found where to get a new kernel for 20.04 is this:
