• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 5.0
• TensorRT Version 7.1
• Issue Type( questions, new requirements, bugs) Question
I have a custom low level tracker library implementation for the gst-nvdstracker plugin. I have enabled/set pQuery->supportbatchprocessing = true in the NvMOT_Query() implementation. I have also implemented NvMOT_RemoveStreams() to clean up resources internal to the tracker when a stream is removed/unavailable for further processing but other streams in the batch are available.
I’m using video files as sources for my deepstream-app pipeline that performs object detection on a batch of N streams and the custom low level tracker library operates on the detected objects and the tracked objects are displayed using nvosd. The video sources are all varying lengths so the input streams for the deepstream app terminate at different times. I was expecting the gst-nvtracker plugin to call the NvMOT_RemoveStreams() implementation of the low level library when the video sources are exhausted but I don’t see that happening. I would like to understand if this is the expected behavior when using file sources for video or if something is not working right.
Thanks,
Dilip.
