I get this nvopencc error:
2>### Assertion failure at line 539 of …/…/be/cg/NVISA/expand.cxx:
2>### Compiler Error in file c:/windows/temp/tmp_00000588-2.i during Code_Expansion phase:
2>### logical_and of un-normalized operand
2>nvopencc ERROR: D:\CUDA\bin/…/open64/lib//be.exe returned non-zero status 1
Any hint is welcome
XP, latest SDK and driver.
I posted the same question before:
http://forums.nvidia.com/index.php?showtopic=33903
I will repeat the error I am getting here to merge the two threads.
Hopefully, someone will consider this thread with any hint. I am totally stuck with this error.
-MH
Can you provide a repro case (.cu file + compile command)?
Yes, I can reproduce it. I have a visual studio 2005 project. Where shall i send the files to?
If you are a registered developer, please, file a bug report with the repro case attached.
