I tried to use textures recently and was stopped by the following compiler error:
#$ nvopencc -TARG:sm_10 -O0 -m32 "simpletest.cpp3.i" -o "simpletest.ptx"
### Assertion failure at line 783 of ../../be/cg/NVISA/exp_loadstore.cxx:
### Compiler Error in file simpletest.cpp3.i during Code_Expansion phase:
### texture variable NYI
nvopencc INTERNAL ERROR: [...]/cuda/toolkit-1.0-i386/open64/lib//be returned non-zero status 1
# --error 0x100 --
make: *** [obj/debug/simpletest.cu_o] Error 255
The following pretty useless code will trigger it:
#include <stdio.h>
#include <stdlib.h>
#include <cuda.h>
#include <cutil.h>
texture<unsigned int, 1, cudaReadModeElementType> tex;
__global__ void tex_kern( unsigned int *g_out, unsigned int *g_in ) {
g_out[threadIdx.x] = tex1Dfetch( tex, threadIdx.x );
// g_out[threadIdx.x] = g_in[threadIdx.x];
int main(void) {
const int num_threads = 32;
unsigned int *g_out, *g_in;
unsigned int h_in[num_threads], h_out[num_threads];
// allocate global memory for output
CUDA_SAFE_CALL( cudaMalloc((void**)&g_out, sizeof(h_in) ));
CUDA_SAFE_CALL( cudaMalloc((void**)&g_in , sizeof(h_in) ));
// fill in some values
for( int i = 0; i < num_threads; i++ )
h_in[i] = rand();
// copy memory to device
CUDA_SAFE_CALL( cudaMemcpy( g_in, h_in, sizeof(h_in), cudaMemcpyHostToDevice ));
CUDA_SAFE_CALL( cudaBindTexture( 0, tex, g_in, sizeof(h_in) ));
dim3 grid( 1,1,1 );
dim3 threads( num_threads, 1, 1 );
tex_kern<<< grid, threads >>>( g_out, g_in );
CUDA_SAFE_CALL( cudaThreadSynchronize( ));
// fetch & output result
CUDA_SAFE_CALL( cudaMemcpy( h_out, g_out, sizeof(h_out), cudaMemcpyDeviceToHost ));
printf( "%s%d\t%d\n", (h_in[i] == h_out[i])? " " : "! ", h_in[i], h_out[i] );
// clean up
CUDA_SAFE_CALL( cudaFree( g_in ));
CUDA_SAFE_CALL( cudaFree( g_out ));
return 0;
Am I missing something important here?
Some CUDA versions:
Built on Wed_Jun_20_21:03:10_PDT_2007
Cuda compilation tools, release 1.0, V0.2.1221
NVIDIA (R) CUDA Open64 Compiler
Built on 2007-06-20 20:57:00 -0700
My system: Ubuntu Feisty Fawn, x86_64 arch.
Can anyone reproduce that error, or (even better) tell me what’s wrong? Any help appreciated!
Thanks,
Robert
