When I try and call
sudo nvpmodel –m 0
or
sudo nvpmodel –h
I get the following errors:
NVPM ERROR: BUG: unhandled option combination optMask = 0x0!
NVPM ERROR: Failed to exec option requests!
When I try and call
sudo nvpmodel –m 0
or
sudo nvpmodel –h
What release are you using? E.g., “head -n 1 /etc/nv_tegra_release”. These work for me on R28.2 (and I’ve used them previously in R28.1).
I have solved the issue.
The problem was from out flashing process. We were capturing images using the command
sudo ./flash.sh -r -k APP -G imagename.img elroy-usb3 mmcblk0p1
and flashing using
sudo ./flash.sh -r -k APP elroy-usb3 mmcblk0p1.
Turns out, we needed to flash all partitions, not just APP.
The correct command for flashing after capturing an image and for us is
sudo ./flash.sh -r elroy-usb3 mmcblk0p1
