Nvsipl_camera configuration for srcRect, desRect, output format
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
I’d like to make customized srcRect, desRect, output format for nvsipl_camera example.
Please provide some guide line for that.
Dear @wooseok.won,
Did you check --icrop parameter ? Could you elaborate a bit on the requirement. Is it like you want to select a specific portion from the image(srcRect) and resize the image(dstRect)?
Dear @SivaRamaKrishnaNV,
I’ve been working on the application which gets image data and then send it to ROS topic.
I found nvsipl_camera example is suitable for acquiring real-time image data an delivery it to my host application. Forum tickets 305570 and 305568 are related with the application.
Here is brief requirement.
  • Host application
    1. Set parameters
      -. Sensor : ar0820 onsemi
      -. Source Rect (x0, x1, y0, y1) by array → multiple interested areas
      ex. [ 4, 3844, 4, 2164], [1668, 2180, 970, 1258]
      -. Destination Rect(width, height) by array → paired with Source Rect
      ex. [ 960, 540], [ 512, 288]
      -. Port : a0 ~ d3 per Sensor
      ex. two ar0820 cameras connected on a0, a1 each.
      -. Frame_rate : 30 (Hz)
      -. Display Rect for the 1st camera : x0, y0, width, height
      -. Output format : YUV422 or RGBA
    2. Call (modified) nvsipl_camera app with passing defined parameters above
    3. Callback function from nvsipl_camera app with updated NvSciBufObj from OnFrameAvailable func
  • nvsipl_camera application
    1. main.cpp modified for having class and arguments from Host application
      int main(int argc, char *argv)
      replaced by
      int ApplSipl::Init(CCmdLineParser& params, std::function<void(const int id, NvSciBufObj* buffer)> callback_fnptr)
      -. Please refer to the attached file which shared in 305580 ticket
      No image on monitor during running nvsipl_camera based application - #4 by wooseok.won
      -. Given parameters need to be applied into the pipleline
      → Multiple Source Rect
      → Multiple Destination Rect
      → Output format
      -. NvSciBufObj pointer in the user callback function should have
      → Image data by given format
      → Host application shall be able to copy all the necessary data from the NvSciBufObj
@SivaRamaKrishnaNV
Please make this ticket as private one.
icrop only support vertical direction. → NVIDIA DRIVE OS Linux SDK API Reference: nvsipl::NvSIPLDownscaleCropCfg Struct Reference | NVIDIA Docs
Dear @wooseok.won,
Does this topic still need support?
Yes, it would be great if I can get a support for this topic.
