GPU • DeepStream Version
6.0.1 • NVIDIA GPU Driver Version (valid for GPU only)
Nvidia T4 GPU • Issue Type( questions, new requirements, bugs)
Questions
I faced the same issue as a previous thread:
I am using the nvcr.io/nvidia/deepstream:6.0.1-devel docker image. Just a some quick questions, is this a known bug and has this been fixed in the newer versions of deepstream?
Thanks for the clarification, I must have missed it out in the documentation.
However, this doesn’t seem to match up with the uint16 cap of 65535 that I am experiencing with the object id. If it was 32-bit unsigned integer, it should have a cap of 4,294,967,294.
I’ve also checked from the config file from “/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml” that the useUniqueID is turned off (by default).
Do you think this is due to a bug? Will upgrading to deepstream 6.4 solve it?
