I am wondering what is the maximum id that an object can take from nvtracker because the IDs in the pipeline is always increasing I want to know if I let my pipeline running for days will it reset the IDs if it reached the maximum of its datatype ? and what is the maximum id that the object could take ?
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
I am running Deepstream 5.1 on Dell G5 15 the GPU is GTX 1650ti the OS is Ubuntu 18.04.5LTS tensorrt version 7.2.3.4 GPU Driver 460.39 CUDA version 11.2
Yeah, it will override the previous ID, what’s the issue did you meet?
