Hi community,
I’ve purchased the ON1(2023) software and I can’t started at all. After some emails with them no solution was found. They said that my laptop use the primary video card instead of the high performance nVidia video card, but they are wrong. I analyzed the crash .dmp file and there is an issue of the memory management in the nvoglv64.dll.
Here is the code:
Exception Analysis * -
KEY_VALUES_STRING: 1
Key : AV.Fault
Value: Execute
Key : Analysis.CPU.mSec
Value: 1327
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 58520
Key : Analysis.IO.Other.Mb
Value: 31
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 45
Key : Analysis.Init.CPU.mSec
Value: 530
Key : Analysis.Init.Elapsed.mSec
Value: 38873
Key : Analysis.Memory.CommitPeak.Mb
Value: 230
Key : Timeline.Process.Start.DeltaSec
Value: 4
Key : WER.OS.Branch
Value: co_release
Key : WER.OS.Timestamp
Value: 2021-06-04T16:28:00Z
Key : WER.OS.Version
Value: 10.0.22000.1
Key : WER.Process.Version
Value: 17.0.1.12965
FILE_IN_CAB: ON1 Photo RAW 2023.exe.11228.dmp
NTGLOBALFLAG: 0
PROCESS_BAM_CURRENT_THROTTLED: 0
PROCESS_BAM_PREVIOUS_THROTTLED: 0
APPLICATION_VERIFIER_FLAGS: 0
CONTEXT: (.ecxr)
rax=0000020f20047200 rbx=0000020f19cd6d40 rcx=0000020f19cd6d40
rdx=0000000000000000 rsi=0000000000000000 rdi=0000020f20047200
rip=0000000000000000 rsp=00000028012ff9c8 rbp=0000000000000000
r8=000000000000081a r9=0000020f20331830 r10=00007ffcdb08ab40
r11=00000028012ff940 r12=00007ffce3e987c4 r13=0000000000000001
r14=0000020f19cd6d40 r15=0000020f19a84940
iopl=0 nv up ei pl nz na po nc
cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00010206
00000000`00000000 ?? ???
Resetting default scope
EXCEPTION_RECORD: (.exr -1)
ExceptionAddress: 0000000000000000
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000008
Parameter[1]: 0000000000000000
Attempt to execute non-executable address 0000000000000000
PROCESS_NAME: ON1 Photo RAW 2023.exe
EXECUTE_ADDRESS: 0
FAILED_INSTRUCTION_ADDRESS:
+0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%p referenced memory at 0x%p. The memory could not be %s.
EXCEPTION_CODE_STR: c0000005
EXCEPTION_PARAMETER1: 0000000000000008
EXCEPTION_PARAMETER2: 0000000000000000
STACK_TEXT:
00000028012ff9c8 00007ffcd8fb94b7 : 0000020f19cd6d40 0000000000000000 0000000000000000 0000020f19a84940 : 0x0
00000028012ff9d0 00007ffcdd660232 : 0000020f19cd7e40 0000000000000000 0000020f19cd6d40 00007ffce4524228 : nvoglv64!DrvPresentBuffers+0x3689a7
00000028012ffa00 00007ffce38a62ef : 00007ffce4520910 0000020f19cd6d40 0000000000000000 0000020f19a918b0 : vulkan_1!vkDestroyDescriptorPool+0x41a52
00000028012ffa30 00007ffd9876bea0 : 0000020f19a857f8 0000020f19a918b0 0000020f19a84940 00007ffce3e987c4 : ONQtCore!ONVKInstance::~ONVKInstance+0x5f
00000028012ffa60 00007ffd9876bdb7 : 0000000000000000 00000028012ffb38 00000028012ffe20 00007ffd988512b0 : ucrtbase!<lambda_f03950bc5685219e0bcd2087efbe011e>::operator()+0xb0
00000028012ffab0 00007ffd9876bd6d : 0000000000000000 0000000000000001 00007ffd820495f0 00000028012ffb28 : ucrtbase!__crt_seh_guarded_call::operator()<<lambda_7777bce6b2f8c936911f934f8298dc43>,<lambda_f03950bc5685219e0bcd2087efbe011e> &,<lambda_3883c3dff614d5e0c5f61bb1ac94921c> >+0x3b
00000028012ffae0 00007ffce3e9862d : 00007ffce456bd00 0000000000000002 0000000000000002 00000028012ffb20 : ucrtbase!execute_onexit_table+0x3d
00000028012ffb20 00007ffce3e98752 : 0000000000000001 00000028010f0000 0000020f17465cc0 00007ffd9af37c95 : ONQtCore!ONExploreWatcherController::qt_metacast+0x5fad
00000028012ffb60 00007ffd9ae9ff07 : 00007ffce3390000 0000000000000000 0000000000000001 000000007ffe0385 : ONQtCore!ONExploreWatcherController::qt_metacast+0x60d2
00000028012ffbc0 00007ffd9aeb44fc : 0000020f17465f20 00007ffce3390000 0000020f00000000 00000028010f0000 : ntdll!LdrpCallInitRoutine+0x6b
00000028012ffc30 00007ffd9aeb42ed : 0000000000000005 0000000000000000 0000000000000000 0000000000000000 : ntdll!LdrShutdownProcess+0x1ec
00000028012ffd40 00007ffd9908cc9b : ffffffff00070001 0000000000000000 fffffffffffffffe 00000028012ffe20 : ntdll!RtlExitUserProcess+0xad
00000028012ffd70 00007ffd98769fec : 0000000000000005 0000000000000000 00000028012ffe00 00007ffd988512b0 : kernel32!ExitProcessImplementation+0xb
00000028012ffda0 00007ffd9876a0c1 : 0000000000000005 0000000000000000 0000020f00000001 00000028012ffdf0 : ucrtbase!exit_or_terminate_process+0x44
00000028012ffdd0 00007ff765017a9c : 0000000000000005 0000000000000000 0000000000000000 0000000000000001 : ucrtbase!common_exit+0x79
00000028012ffe30 00007ffd99085550 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : ON1_Photo_RAW_2023+0xba7a9c
00000028012ffe70 00007ffd9ae6485b : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : kernel32!BaseThreadInitThunk+0x10
00000028012ffea0 0000000000000000 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : ntdll!RtlUserThreadStart+0x2b
STACK_COMMAND: ~0s; .ecxr ; kb
SYMBOL_NAME: nvoglv64+3689a7
MODULE_NAME: nvoglv64
IMAGE_NAME: nvoglv64.dll
FAILURE_BUCKET_ID: SOFTWARE_NX_FAULT_c0000005_nvoglv64.dll!Unknown
OS_VERSION: 10.0.22000.1
BUILDLAB_STR: co_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
IMAGE_VERSION: 31.0.15.2698
FAILURE_ID_HASH: {28ebf084-ef70-f71a-044f-3aef9999f8fe}
Followup: MachineOwner
My laptop has Win11Pro installed and two video card on it: (extras from dxdiag)
Display Devices
Card name: AMD Radeon(TM) Graphics
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x1636)
DAC type: Internal DAC(400MHz)
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_1002&DEV_1636&SUBSYS_16CF1043&REV_C6
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 8392 MB
Dedicated Memory: 496 MB
Shared Memory: 7895 MB
Current Mode: 1920 x 1080 (32 bit) (144Hz)
HDR Support: Not Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.639648,0.330078), Green(0.299805,0.599609), Blue(0.149414,0.059570), White Point(0.312500,0.329102)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: AUO8294
Native Mode: 1920 x 1080(p) (144.028Hz)
Output Type: Internal
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: Not Supported
Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\u0367465.inf_amd64_f448bc468601f23f\B367478\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\u0367465.inf_amd64_f448bc468601f23f\B367478\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\u0367465.inf_amd64_f448bc468601f23f\B367478\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\u0367465.inf_amd64_f448bc468601f23f\B367478\amdxc64.dll
Driver File Version: 27.20.11032.9001 (English)
Driver Version: 27.20.11032.9001
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.7
Hardware Scheduling: DriverSupportState:AlwaysOff Enabled:False
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported by Graphics driver
Detachable GPU: No
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: DISABLE_HWSCH
Catalog Attributes: Universal:False Declarative:True
Driver Attributes: Final Retail
Driver Date/Size: 5/5/2021 2:00:00 AM, 1983864 bytes
WHQL Logo’d: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B71EE2-5576-11CF-DA50-D71D7DC2D635}
Vendor ID: 0x1002
Device ID: 0x1636
SubSys ID: 0x16CF1043
Revision ID: 0x00C6
Driver Strong Name: oem38.inf:cb0ae414f26f8f4a:ati2mtag_Renoir:27.20.11032.9001:PCI\VEN_1002&DEV_1636&SUBSYS_16CF1043&REV_C6
Rank Of Driver: 00CF0000
Video Accel: Unknown
DXVA2 Modes: DXVA2_ModeMPEG2_VLD {86695F12-340E-4F04-9FD3-9253DD327460} DXVA2_ModeH264_VLD_NoFGT {4245F676-2BBC-4166-A0BB-54E7B849C380} {6719B6FB-5CAD-4ACB-B00A-F3BFDEC38727} {9901CCD3-CA12-4B7E-867A-E2223D9255C3} DXVA2_ModeHEVC_VLD_Main {EA72396A-67EC-4781-BEDE-56F498F04EF2} {C152CA8F-738C-461B-AD89-FC292CF8F162} {514A356C-7027-4AFF-8A60-AFD2C1F672F1} DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeVC1_VLD {CA15D19A-2B48-43D6-979E-7A6E9C802FF8} {D1C20509-AE7B-4E72-AE3B-49F88D58992F} {84AD67F6-4C21-419A-9F0B-24F0578906C1} {725AD240-786C-471E-AD3C-38F739936517} {95664FF5-9E03-4C74-BB4F-9178D6035E58} {5EF7D40D-5B96-49E7-B419-23342094A4CF} DXVA2_ModeHEVC_VLD_Main10 {65D1FA41-58AF-453A-9CAB-5D981156DA9F} {2DB154B6-DBB2-4079-A3FF-60D7A898A6AB} {C74A3FD0-D713-4581-A02E-8EDFB112ACE3} DXVA2_ModeVP9_VLD_Profile0 DXVA2_ModeVP9_VLD_10bit_Profile2 {603A4756-A864-4F91-BB62-2C935B7A1391}
Deinterlace Caps: n/a
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 2
MPO Caps: ROTATION,VERTICAL_FLIP,HORIZONTAL_FLIP,YUV,BILINEAR,STRETCH_YUV,HDR (MPO3)
MPO Stretch: 16.000X - 0.250X
MPO Media Hints: rotation, resizing, colorspace Conversion
MPO Formats: NV12,420_OPAQUE
PanelFitter Caps: ROTATION,VERTICAL_FLIP,HORIZONTAL_FLIP,YUV,BILINEAR,STRETCH_YUV,HDR (MPO3)
PanelFitter Stretch: 16.000X - 0.250X
Component Drivers:
Driver Name: Unknown
Driver Version: Unknown
Driver Date: Unknown
Driver Provider: Unknown
Catalog Attributes: N/A
Card name: **NVIDIA GeForce GTX 1650**
Manufacturer: NVIDIA
Chip type: NVIDIA GeForce GTX 1650
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_1F99&SUBSYS_18CF1043&REV_A1
Display Memory: 11845 MB
Dedicated Memory: 3950 MB
Current Mode: Unknown
HDR Support: Unknown
Display Topology: Unknown
Display Color Space: Unknown
Color Primaries: Unknown
Display Luminance: Unknown
Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_a5ef29d5e04efca5\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_a5ef29d5e04efca5\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_a5ef29d5e04efca5\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_a5ef29d5e04efca5\nvldumdx.dll
Driver File Version: 31.00.0015.2698 (English)
Driver Version: 31.0.15.2698
DDI Version: 12
Driver Model: WDDM 3.0
Hardware Scheduling: DriverSupportState:Stable Enabled:True
Graphics Preemption: Pixel
Compute Preemption: Dispatch
Detachable GPU: No
Hybrid Graphics GPU: Discrete
Block List: No Blocks
Driver Date/Size: 11/13/2022 2:00:00 AM, 772496 bytes
WHQL Logo’d: Yes
Device Identifier: Unknown
Vendor ID: 0x10DE
Device ID: 0x1F99
SubSys ID: 0x18CF1043
Revision ID: 0x00A1
Driver Strong Name: oem27.inf:0f066de3a4aee684:Section114:31.0.15.2698:pci\ven_10de&dev_1f99&subsys_18cf1043
Rank Of Driver: 00CF0001
DXVA2 Modes: {86695F12-340E-4F04-9FD3-9253DD327460} DXVA2_ModeMPEG2_VLD {6F3EC719-3735-42CC-8063-65CC3CB36616} DXVA2_ModeVC1_D2010 DXVA2_ModeVC1_VLD {32FCFE3F-DE46-4A49-861B-AC71110649D5} DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 {20BB8B0A-97AA-4571-8E99-64E60606C1A6} {15DF9B21-06C4-47F1-841E-A67C97D7F312} DXVA2_ModeMPEG4pt2_VLD_Simple DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC {9947EC6F-689B-11DC-A320-0019DBBC4184} {33FCFE41-DE46-4A49-861B-AC71110649D5} DXVA2_ModeVP9_VLD_Profile0 DXVA2_ModeVP9_VLD_10bit_Profile2 {DDA19DC7-93B5-49F5-A9B3-2BDA28A2CE6E} {6AFFD11E-1D96-42B1-A215-93A31F09A53D} {914C84A3-4078-4FA9-984C-E2F262CB5C9C}
D3D9 Overlay: Unknown
DXVA-HD: Unknown
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 0
MPO Caps: Not Supported
MPO Stretch: Not Supported
MPO Media Hints: Not Supported
MPO Formats: Not Supported
PanelFitter Caps: Not Supported
PanelFitter Stretch: Not Supported
Any help would be highly appreciated.
Cheers,
Holi
