I have a 2 machines which are connected to a S1070. Each machine obviously sees 2 C1060 (half of the S1070) and if
I run deviceQuery I see all 4 C1060. However if I run a sample test from the SDK (reduction for example but any other application)
one of the machines will hang on device 0 and succeed on device 1 and the second machine will succeed on device 0 and hang on device 1.
Any ideas why? is it cable related?
I’m using CUDA 2.3 and my linux system is: Linux qa-slave5 2.6.18-92.el5 #1 SMP Tue Apr 29 13:16:15 EDT 2008 x86_64 x86_64 x86_64 GNU/Linux
Also, from time to time (after a crash or a reboot usually) the following files just dissapper and then deviceQuery returns only enumeration mode instead
of the 4 cards:
/dev/nvidiactl
/dev/nvidia1
/dev/nvidia2
if I manually create thos files like this:
mknod -m 0666 /dev/nvidiactl c 195 255
mknod -m 0666 /dev/nvidia0 c 195 0
mknod -m 0666 /dev/nvidia1 c 195 1
the system sees the cards again and its working as described above.
any assistance would be very appriciated.
EDIT:
furthermore if I run bandwidth test on the “faulty” device I get this:
-bash-3.2$ ./bandwidthTest --device=0
Running on......
device 0:Tesla C1060
Quick Mode
Host to Device Bandwidth for Pageable memory
Transfer Size (Bytes) Bandwidth(MB/s)
33554432 2150.8
Quick Mode
Device to Host Bandwidth for Pageable memory
33554432 1268.2
Quick Mode
Device to Device Bandwidth
the Device to Device bandwidth just hangs…
the same on the “valid/working” device works just fine…
thanks
eyal
