OpenCL compilation fails with `Unresolved extern function '__nv_fast_exp2f'` with drivers 470.42.01
I was trying to debug an opencl problem in darktable, but noticed that after recent update I can’t compile some opencl kernels.
The compiller options are:
-w -DNVIDIA_SM_20=1 -DNVIDIA=1 -I"/usr/share/darktable/kernels"
and the error:
11.123762 [opencl_build_program] could not build program: -9999
11.123793 [opencl_build_program] BUILD STATUS: -2
11.123809 BUILD LOG:
11.123814 ptxas fatal   : Unresolved extern function '__nv_fast_exp2f'
11.123821 [opencl_init] failed to compile program `blendop.cl'!
the error happens for darktable 3.4.1 as well as current pre-release
the cl kernels used to be non-problematic in any previous version, most recently with 465.31 :)
(darktable uses native_log2 in filmic.cl however the error is in blendop.cl)
Thanks for reporting the bug.
We are working on the fix and expect this to be fixed for upcoming release.
Hi, 471.11 still does not have this fixed. Are you referring to the next release after this version?
