I have installed on my 32bit xp, the gpu computing sdk and all the required drivers; i also have microsoft visual c++ 2008.
The examples given in the SDK work well, but when i create a project in the directory where all the examples are, i can’t compile it, i have the errors :
“general error c1010070: Failed to load and parse the manifest”
“‘OpenCLSource’ : undeclared identifier”
the code i tried is the one given by nvidia in “NVIDIA_OpenCL_GettingStartedWindows.pdf” p14 ( i attached it to my post)
Do have an idea that may help me solve this problem?
Does someone have a simple opencl code like “Hello World”?
Thank you NVIDIA_OpenCL_GettingStartedWindows.pdf (2.56 MB)
I’m trying to run a OpenCL solution with Visual Studio 2008.
I make all the changes in VS2008 until 10th step in the file that u show.
On 10th and 11th I don’t know how to do with OpenCL.
My problem when I try to run or debug a solution is in cl_platform that has this sintaxe (attribute((aligned(2)))) and everytime has an error in this line.
I search on Google and I find this sintaxe is diferent in GCC compiler and CL compiler.
And on CL compiler this sintaxe is __declspec(align(2)).
