i installed the driver, toolkit and the sdk, in that order
typing nvcc -V in the command prompt gives the correct response
i can run the sample executable files that come with the SDK
however, i can not compile any of the example programs in visual C++
using cuda 2.3 (64 bit version of the driver, toolkit and sdk)
visual C++ express edition
windows 7 professional edition 64 bit
Nvidia geforce 9400m g
core 2 duo 2.1 ghz
3 gb ram
i think i installed everything into their default directories.
i read something about goign into tools → options → projects and solutions → VC++ directories and adding include and library files and that is also not working.
what files exactly do i need to include?
I have also run CUDA_VS_Wizard_W32.2.0 with no success
my build log for when i try to compile matrixMul_vc90 (a sample program that came with the SDK) is attached first
my build log for compiling the sample cuda program that came with the CUDA VS WIZARD template is attached second
please help!
BuildLog.htm (11.1 KB)
BuildLog.htm (8.78 KB)
