• Hardware Platform (Jetson / GPU) : Jetson Nano • DeepStream Version : 5.0 • JetPack Version : 4.5 • TensorRT Version : 7.1.3.0
I have used this link to install openpose in jetson nano. I was able to install openpose succesfully.
After that I used this command. “./build/example/openpose/openpose.bin --image_dir images/” to run Openpose.
In Images folder, there is only one image. I ran this command, and output windows appears after few seconds everything got stuck and then “Killed” Message was there on terminal.
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
Do you mee this error when running SDK manager?
If yes, would you mind removing the download packages and trying it again?
