Hi! There is a problem, the video driver does not work correctly, the msi gtx 1660 super ventus xs oc card is used, 2 monitors, at different times an artifact appears in the form of a strip at the top of the screen, it is not displayed in windows, the card works fine. Help me!
Example of an artifact, as I see it, only the black color of the strip
I drew the strip myself)
Openbox also has this artifact in the same place
Operating System: openSUSE Leap 15.2
KDE Plasma Version: 5.18.5
KDE Frameworks Version: 5.71.0
Qt Version: 5.12.7
Kernel Version: 5.3.18-lp152.50-default
OS Type: 64-bit
Processors: 6 × Intel® Core™ i5-9400F CPU @ 2.90GHz
Memory: 15.6 GiB of RAM
nvidia: version 450.80.02
[gdsmith@linuxzion ~]$ cat /etc/X11/xorg.conf [17:48:30]
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 450.80.02
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 450.80.02
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from data in "/etc/sysconfig/mouse"
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "IMPS/2"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "yes"
Option "ZAxisMapping" "4 5"
EndSection
# generated from default
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Microstep MSI MP241"
HorizSync 30.0 - 83.0
VertRefresh 48.0 - 75.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX 1660 SUPER"
EndSection
Section "Screen"
# Removed Option "metamodes" "HDMI-0: nvidia-auto-select +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}, DP-1: nvidia-auto-select +1920+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
# Removed Option "metamodes" "HDMI-0: 1920x1080_60 +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}, DP-1: 1920x1080_60 +1920+0"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-4"
Option "metamodes" "HDMI-0: 1920x1080_60 +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}, DP-1: 1920x1080_60 +1920+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
nvidia-bug-report.log.gz (461.4 KB)
