In spite of adding VS2019 build tools in installer i get a long list of errors.
I am not in the mood to edit 21 version checks…
Schweregrad Code Beschreibung Projekt Datei Zeile Unterdrückungszustand
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixNVLink C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. DemandLoading C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\lib\DemandLoading\PagingSystemKernels.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\lib\DemandLoading\CMakeLists.txt" wurde mit dem Code 1 beendet. DemandLoading C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. sutil_7_sdk C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\cuda\sphere.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\cuda\whitted.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\sutil\CMakeLists.txt" wurde mit dem Code 1 beendet. sutil_7_sdk C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixVolumeViewer C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixVolumeViewer\volume.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixVolumeViewer\CMakeLists.txt" wurde mit dem Code 1 beendet. optixVolumeViewer C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixTriangle\optixTriangle.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixTriangle\CMakeLists.txt" wurde mit dem Code 1 beendet. optixTriangle C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixWhitted\camera.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixWhitted\geometry.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixWhitted\shading.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixWhitted\CMakeLists.txt" wurde mit dem Code 1 beendet. optixWhitted C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixSimpleMotionBlur C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixSphere C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixPathTracer C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixOpticalFlow C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixPathTracer\optixPathTracer.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixPathTracer\CMakeLists.txt" wurde mit dem Code 1 beendet. optixPathTracer C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixRaycasting\optixRaycasting.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixRaycasting\optixRaycastingKernels.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixRaycasting\CMakeLists.txt" wurde mit dem Code 1 beendet. optixRaycasting C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixSimpleMotionBlur\optixSimpleMotionBlur.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixSimpleMotionBlur\CMakeLists.txt" wurde mit dem Code 1 beendet. optixSimpleMotionBlur C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixOpticalFlow\optixOpticalFlow.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixOpticalFlow\CMakeLists.txt" wurde mit dem Code 1 beendet. optixOpticalFlow C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixSphere\optixSphere.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixSphere\CMakeLists.txt" wurde mit dem Code 1 beendet. optixSphere C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixDynamicMaterials C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixDynamicGeometry C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixMultiGPU C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixNVLink\optixNVLink_kernels.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixNVLink\optixNVLink.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixNVLink\CMakeLists.txt" wurde mit dem Code 1 beendet. optixNVLink C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixMotionGeometry C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixDynamicMaterials\optixDynamicMaterials.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixDynamicMaterials\CMakeLists.txt" wurde mit dem Code 1 beendet. optixDynamicMaterials C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixDynamicGeometry\optixDynamicGeometry.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixDynamicGeometry\vertices.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixDynamicGeometry\CMakeLists.txt" wurde mit dem Code 1 beendet. optixDynamicGeometry C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixMultiGPU\optixMultiGPU_kernels.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixMultiGPU\optixMultiGPU.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixMultiGPU\CMakeLists.txt" wurde mit dem Code 1 beendet. optixMultiGPU C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixMotionGeometry\optixMotionGeometry.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixMotionGeometry\vertices.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixMotionGeometry\CMakeLists.txt" wurde mit dem Code 1 beendet. optixMotionGeometry C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixHello C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixHair C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixCutouts C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler LNK1104 Datei "..\lib\Debug\sutil_7_sdk.lib" kann nicht geöffnet werden. optixModuleCreateProcess C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\build\optixModuleCreateAbort\LINK 1
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixCurves C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixHair\optixHair.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixHair\CMakeLists.txt" wurde mit dem Code 1 beendet. optixHair C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixHello\draw_solid_color.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixHello\CMakeLists.txt" wurde mit dem Code 1 beendet. optixHello C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler LNK1104 Datei "..\lib\Debug\sutil_7_sdk.lib" kann nicht geöffnet werden. optixDenoiser C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\build\optixDenoiser\LINK 1
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixCallablePrograms C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixBoundValues C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler LNK1104 Datei "..\lib\Debug\sutil_7_sdk.lib" kann nicht geöffnet werden. optixMeshViewer C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\build\optixMeshViewer\LINK 1
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixCutouts\optixCutouts.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixCutouts\CMakeLists.txt" wurde mit dem Code 1 beendet. optixCutouts C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler LNK1104 Datei "..\lib\Debug\sutil_7_sdk.lib" kann nicht geöffnet werden. optixCompileWithTasks C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\build\optixCompileWithTasks\LINK 1
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixDemandLoadSimple C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixCurves\optixCurves.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixCurves\CMakeLists.txt" wurde mit dem Code 1 beendet. optixCurves C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixCallablePrograms\optixCallablePrograms.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixCallablePrograms\CMakeLists.txt" wurde mit dem Code 1 beendet. optixCallablePrograms C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixDemandTexture C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixBoundValues\optixBoundValues.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixBoundValues\optixBoundValues_ch.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixBoundValues\CMakeLists.txt" wurde mit dem Code 1 beendet. optixBoundValues C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixDemandLoadSimple\PageRequester.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixDemandLoadSimple\CMakeLists.txt" wurde mit dem Code 1 beendet. optixDemandLoadSimple C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixDemandTexture\optixDemandTexture.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixDemandTexture\CMakeLists.txt" wurde mit dem Code 1 beendet. optixDemandTexture C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
Fehler C1189 #error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2019 (inclusive) are supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk. optixModuleCreateAbort C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.5\include\crt\host_config.h 160
Fehler MSB8066 Der benutzerdefinierte Build für "C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixModuleCreateAbort\optixModuleCreateAbort.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixModuleCreateAbort\optixModuleCreateAbort_ch.cu;C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.4.0\SDK\optixModuleCreateAbort\CMakeLists.txt" wurde mit dem Code 1 beendet. optixModuleCreateAbort C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets 242
