Hello! Let me check with Engineering to see if there has been any progress. Thanks for your incredible patience! :)
Related topics
Problem running OptiX 7.6 in WSL | 18 | 4467 | June 13, 2025 | |
Libnvoptix.so.1 in WSL not searched upon /usr/lib/wsl/lib | 1 | 4958 | May 11, 2023 | |
OptiX Error: 'Failed to load OptiX library | 51 | 18603 | June 14, 2022 | |
Optix 7.4 samples fail under VS2022 | 4 | 1559 | June 14, 2022 | |
Optix 7.7 in WSL + Docker works with sudo but not as default user | 4 | 155 | May 8, 2025 | |
Optix error: OPTIX_ERROR_LIBRARY_NOT_FOUND in nvidia docker while running optixHello | 3 | 409 | September 13, 2024 | |
Optix v3.7.0 compatibility issue and optix wizard. | 1 | 1038 | June 14, 2022 | |
Tachyon Optix-Rendering not available in NVIDIA driver in Ubuntu 20.04/22.04/22.10 through WSL2 | 0 | 695 | June 16, 2022 | |
sdk example output to file | 22 | 4524 | June 14, 2022 | |
How could i start learning for Optix6 with Windows CUDA10.1? | 11 | 1058 | June 14, 2022 |
