We are trying to set up Secure boot, Secure UEFI, and encrypted internal disk on our Orin AGX on a custom carrier board.
We are running Jetson Linux r36.3 and flashing from a ubuntu 22.04 host. And we already have been successfully able to flash several modules unencrypted and without secure boot, as well as tested one module with disk encryption (zero filled key).
After creating all the keys and making a new eks image (put into bootloader folder) we wrote the fuses and flashed the board. However, upon restarting the device there is no output on UART and it does not seem to boot, does not come up on ethernet like it does for non-secure builds, power draw is very similar to when in recovery mode, and device shows up as “NVIDIA Corp. APX” in lsusb.
We are wondering if you have any ideas as to what can be wrong when the board ends up in this state.
We write the following fuses: PublicKeyHash, SecureBootKey, OemK1, BootSecurityInfo (0x20b), and SecurityMode (0x1):
sudo ./odmfuse.sh -X fuse_t234.xml -i 0x23 --auth NS our_board_name
And after successfully fusing, just to check that board is alive:
sudo ./odmfuse.sh --test -X fuse_t234.xml -k “pkc.pem” -S “sbk.key” -i 0x23 --auth SBKPKC our_board_name
We have tried several different variants of build and flashing procedures usually within the same Linux_for_Tegra and bootloader(!) folder:
Using flash.sh directly (both with internal and mmcblk0p1 and with and without -r after system image has been created by l4t_initrd_flash.sh or l4t_generate_ota_package.sh):
sudo ROOTFS_ENC=1 ROOTFS_AB=1 ROOTFS_RETRY_COUNT_MAX=3 ROOTFSSIZE=30380392448 ./flash.sh -S 30380392448 -u “pkc.pem” -v “sbk.key” -i “sym2_t234.key” --uefi-keys “uefi_keys/uefi_keys.conf” --uefi-enc “sym_t234.key” our_board_name internal -
Creating a massflash (using ./tools/kernel_flash/l4t_initrd_flash.sh) and flashing from the ‘mfi’ folder (booted into initrd, but failed to continue as we did not have xusb/xudc set up in the device tree):
sudo BOARDID=3701 BOARDSKU=0004 FAB=500 BOARDREV=“R.0” CHIPREV=0 CHIP_SKU=“00:00:00:D2” ROOTFS_ENC=1 ROOTFS_AB=1 ROOTFS_RETRY_COUNT_MAX=3 ROOTFSSIZE=30380392448 ./tools/kernel_flash/l4t_initrd_flash.sh -S 30380392448 -u “pkc.pem” -v “sbk.key” -i “sym2_t234.key” --uefi-keys “uefi_keys/uefi_keys.conf” --uefi-enc “sym_t234.key” --no-flash -p “-r --generic-passphrase -c ./bootloader/generic/cfg/flash_t234_qspi_sdmmc_enc_rootfs_ab.xml” --massflash 1 our_board_name internal
sudo echo “-1” > /sys/module/usbcore/parameters/autosuspend
sudo systemctl stop udisks2.service
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 1 -
Creating a OTA package using ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh and then flashing using the above ./flash.sh with “-r”:
sudo BOARDID=3701 BOARDSKU=0004 FAB=500 BOARDREV=“R.0” CHIPREV=0 CHIP_SKU=“00:00:00:D2” ROOTFS_ENC=1 ROOTFS_AB=1 ROOTFS_RETRY_COUNT_MAX=3 ROOTFSSIZE=30380392448 ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh -s -S 30380392448 -u “pkc.pem” -v “sbk.key” -i “sym2_t234.key” -p “-r -c ./bootloader/generic/cfg/flash_t234_qspi_sdmmc_enc_rootfs_ab.xml --uefi-keys "uefi_keys/uefi_keys.conf" --uefi-enc "sym_t234.key"” our_board_name R36-3 -
Flashing with flashcmd.txt/tegraflash.py directly:
bootloader$ sudo bash ./flashcmd.txt
./tegraflash.py --bl uefi_jetson_with_dtb.bin --bct br_bct_BR.bct --bldtb tegra234-p3701-0000-our_board_name-0000-nv.dtb --applet rcm_2_signed.rcm --applet_softfuse rcm_1_signed.rcm --cmd “secureflash;reboot” --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader_encrypt.bct.signed --mem_bct mem_rcm_sigheader_encrypt.bct.signed --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader_encrypt.bct.signed --mb1_bin mb1_t234_prod_aligned_sigheader_encrypt.bin.signed --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader_encrypt.bin.signed --mem_bct_cold_boot mem_coldboot_aligned_sigheader_encrypt.bct.signed --bins “psc_fw pscfw_t234_prod_sigheader_encrypt.bin.signed; mts_mce mce_flash_o10_cr_prod_sigheader_encrypt.bin.signed; tsec_fw tsec_t234_sigheader_encrypt.bin.signed; mb2_applet applet_t234_sigheader_encrypt.bin.signed; mb2_bootloader mb2_t234_with_mb2_bct_MB2_sigheader_encrypt.bin.signed; xusb_fw xusb_t234_prod_sigheader_encrypt.bin.signed; pva_fw nvpva_020_sigheader_encrypt.fw.signed; dce_fw display-t234-dce_sigheader_encrypt.bin.signed; nvdec nvdec_t234_prod_sigheader_encrypt.fw.signed; bpmp_fw bpmp_t234-TE990M-A1_prod_sigheader_encrypt.bin.signed; bpmp_fw_dtb tegra234-bpmp-3701-0004-3737-0000_with_odm_sigheader_encrypt.dtb.signed; rce_fw camera-rtcpu-t234-rce_sigheader_encrypt.img.signed; ape_fw adsp-fw_sigheader_encrypt.bin.signed; spe_fw spe_t234_sigheader_encrypt.bin.signed; tos tos-optee_t234_sigheader_encrypt.img.signed; eks eks_t234_sigheader_encrypt.img.signed”–bct_backup
We are able to reflash the board afterwards, at least run the flash procedure and get the same result and also boot into UEFI and initrd using scripts like tegraflash.py. During trying to make this work we have seen several different errors that might be important:
While building massflash:
“End sector for APP_ENC, expected at: 119537630, actual: 0
Error: Return value 4
Command tegraparser_v2 --generategpt --pt flash.xml.bin
cp: cannot stat ‘enc_signed/*’: No such file or directory
cp: cannot stat ‘enc_signed/flash.xml.tmp’: No such file or directory”
Stat for blob_uefi_jetson_with_dtb.bin failed
Error: Return value 19
Command tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin"
Tried a work around by symlinking or copying to the file found in bootloader folder which let :
sudo ln -sf uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader_encrypt.bin.signed uefi_jetson_with_dtb.bin
And building OTA or using flash.sh created the enc_signed folder with content. -
“[0047.110] C> LOADER: Could not read binary 21.
[0047.114] E> Failed to load MB2
[0047.117] C> Task 0x46 failed (err: 0x27228f37)
[0047.121] E> Top caller module: MB2_PARAMS, error module: LOADER, reason: 0x37, aux_info: 0x8f
[0047.130] C> Boot Info Table status dump :
0111100000111000110111111111000” -
“FATAL ERROR [FILE=platform/drivers/uphy/uphy-tegra234.c, ERR_UID=2251]: start PLL 8 calibration failed
ERROR: camera-ip/isp5/isp5.c:2031 [isp5_pm_init] “ERROR: Failed to turn isp1 power on”
BUG: core/init/init.c:86 [init_all] “*** FIRMWARE INIT FAILED AT LEVEL 95 ***””
Fixed by removing attempt of initialization of 10gbps PHY from p3701.conf.common (did not get this error on unsecure modules with same p3701 config):
#ODMDATA=“gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g”;
ODMDATA=“gbe-uphy-config-0,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0”; -
“I> dump bct
I> strt_pg_num(0) num_of_pgs(16) read_buf(0x400719f8)
E> LOADER: Invalid value Header magic.
E> Validation failed for 1 copy of BRBCT @ 0
I> strt_pg_num(512) num_of_pgs(16) read_buf(0x400719f8)
E> Validation failed for 2 copy of BRBCT @ 262144
I> strt_pg_num(1024) num_of_pgs(16) read_buf(0x400719f8)
E> Validation failed for 3 copy of BRBCT @ 524288
I> strt_pg_num(1536) num_of_pgs(16) read_buf(0x400719f8)
E> Validation failed for 4 copy of BRBCT @ 786432
E> NV3P_SERVER: Failed to get address for br bct from nv3p helper.”
Messed about a lot with this, seemed sometimes to work with using a different br_bct_BR.bct file (e.g. from OTA or massflash build or vice versa) -
“[0121.337] I> Task: Load MB2/Applet/FSKP
[0121.341] I> Loading MB2 Applet
[0121.344] I> Slot: 1
[0121.347] E> BLOCK_DEV: Failed to open blockdev.
[0121.352] E> LOADER: Failed to open blockdev 0(0).
[0121.357] E> LOADER: Failed to get storage info for binary 21 from loader.
[0121.364] C> LOADER: Could not read binary 21.”
Other things that might be important:
- We have tried fusing and flashing this secure boot setup on two different Orin modules and they have different revision number: L.0 and R.0
Also they seem to report (when queried by flash.sh) different values for BOARDREV, CHIPREV, and CHIP_SKU:
./chkbdinfo -i cvm.bin
3701
./chkbdinfo -k cvm.bin
0004
./chkbdinfo -f cvm.bin
500
./chkbdinfo -r cvm.bin
L.0
./chkbdinfo -C cvm.bin
00:FE:00:02
From massflash flash-only log:
“[ 17.3102 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 17.3111 ] MB2 Applet version 01.00.0000
Board ID(3701) version(500) sku(0004) revision(L.0)
Chip SKU(00:00:00:D2) ramcode(00:00:00:00) fuselevel(fuselevel_production) board_FAB(500)”
We have tried with BOARDID=3701 BOARDSKU=0004 FAB=500 and BOARDREV=L.0 or BOARDREV=R.0 CHIPREV=0 or CHIPREV=1 CHIP_SKU=00:FE:00:02 or CHIP_SKU=00:00:00:D2 when building/flashing.
We have as you can see created a custom partition flash.xml:
flash_t234_qspi_sdmmc_enc_rootfs_ab.xml based on the encrypted A/B xml, with two additional userdata partitions (encrypt, not reencrypt) just before the UDA partition. And decreased the rootfs partition size accordingly (both A and B)
The our_board_name.conf file has the following flags added from working non-secure setup:
rootfs_ab=1;
#EMMC_CFG=“flash_t234_qspi_sdmmc_rootfs_ab.xml”;
disk_enc_enable=1;
EMMC_CFG=“flash_t234_qspi_sdmmc_enc_rootfs_ab.xml”;
We will try to create a new minimal setup (new Linux_for_Tegra folder ;) ) using only flash.sh directly (not no-flash) to try to make a reproducible log, but appreciate if you have any ideas while we do. :)
