Can data be processed on AGX Orin while it is being transferred from FPGA via PCIe, allowing for the processing of the portion of data that has been transferred before the entire transfer is completed?
Is the frame data sending from FPGA to Orin through PCIe? Or frame data is on Orin and would like to let FPGA access it? Would like to confirm which direction is in your use-case so that we can suggest next.
Yes,the frame data send from FPGA to Orin through PCIe
