Orin模块的载板设计使用了hdmi,系统文件应该如何修改
在设计jetson agx orin 64GB工业版载板时,视频输出接口使用了HDMI设计,烧入系统时,应该如何修改系统文件以适配HDMI接口
The Jetson AGX Orin 64GB module is a production module that is compatible with the Jetson AGX Orin reference carrier board (P3737-0000). It has 64GB of memory and is designed for production use. The module is sold separately and is intended for deployment in a production environment throughout its operating lifetime.
In comparison to the Jetson AGX Orin 32GB module, the 64GB module has more memory, but the performance is the same except for the memory. The price of the Jetson AGX Orin developer kit with 64GB of memory is $1999.
It’s worth noting that the Jetson AGX Orin 64GB module is part of the NVIDIA Jetson AGX Orin series, which includes other modules such as the Jetson AGX Orin 32GB (P3701-0004) and the Jetson AGX Orin Industrial (P3701-0008). These modules have similar characteristics, including identical partition configurations.
In terms of HDMI, the Jetson AGX Orin 64GB module has HDMI support, but the specific details of the HDMI implementation are not provided in the context. However, it’s likely that the module has HDMI output capabilities, given its design for production use and deployment in a variety of applications.
Overall, the Jetson AGX Orin 64GB module is a powerful and versatile module that is well-suited for a wide range of applications, including those that require high-performance computing and AI capabilities.
if this is jetpack5, then below post could help.
if this is jetpack6, then need to follow p3509+p3767 config from orin nano and modify a new one for orin agx.
