[ 14.161714] ALSA device list:
[ 14.164770] No soundcards found.
[ 14.168838] Freeing unused kernel memory: 3968K
[ 14.173568] Run /init as init process
[ 14.188844] Root device found: mmcblk0p1
[ 14.193354] Found dev node: /dev/mmcblk0p1
[ 14.216727] EXT4-fs (mmcblk0p1): bad geometry: block count 15158963 exceeds size of device (15158784 blocks)
[ 14.227163] ERROR: mmcblk0p1 mount fail...
[ 44.542306] vdd-12v-sys: disabling
[ 44.545814] vdd-3v3-ftdi: disabling
[ 44.549413] dsi-vdd-1v8-bl-en: disabling
如上串口打印信息,显示mmcblk0p1块大小错误,启动终止,请问该如何解决?或者是否能提供进入系统备份资料的方式然后重新刷机
