I have a jetson orin nano super dev kit with the latest jetpack installed. (I think 6.1 or 6.2?)
Im trying to connect it with an IMX477 ir-cut 12.3mp camera, however, I just cannot get it to work.
First of all, the camera was provided with 2 cables. An orange one and a white one. According to the tutorial by arducam, I should use the orange, because it has been connected to the camera when shipped. That is not the case for me at all, and I am unable to do anything with the orange thing. (It has UC-693 written on it)
I connected the white cable both ways on both slots (CAM0, CAM1), however, none of them seem to work.
I have the following logs:
‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1’ !
nvvidconv ! nvegltransform ! nveglglessink
Setting pipeline to PAUSED …
Using winsys: x11
Pipeline is live and does not need PREROLL …
Got context from element ‘eglglessink0’: gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:794 No cameras available
Redistribute latency…
WARNING: from element /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0: Pipeline construction is invalid, please add queues.
Additional debug info:
../libs/gst/base/gstbasesink.c(1249): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0:
Not enough buffering available for the processing deadline of 0:00:00.015000000, add enough queues to buffer 0:00:00.015000000 additional data. Shortening processing latency to 0:00:00.000000000.
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.119371253
Setting pipeline to NULL …
Freeing pipeline …
hzjarvis@hzjarvis-desktop:~$
dmesg | grep -i imx477
hzjarvis@hzjarvis-desktop:~$ sudo dmesg | grep -i imx477
[sudo] password for hzjarvis:
[ 11.212949] imx477 9-001a: tegracam sensor driver:imx477_v2.0.6
[ 11.513567] imx477 9-001a: imx477_board_setup: error during i2c read probe (-121)
[ 11.513602] imx477 9-001a: board setup failed
[ 11.513673] imx477: probe of 9-001a failed with error -121
[ 11.516139] imx477 10-001a: tegracam sensor driver:imx477_v2.0.6
[ 11.816719] imx477 10-001a: imx477_board_setup: error during i2c read probe (-121)
[ 11.816750] imx477 10-001a: board setup failed
[ 11.816838] imx477: probe of 10-001a failed with error -121
hzjarvis@hzjarvis-desktop:~$ ls /dev/video*
ls: cannot access ‘/dev/video*’: No such file or directory
hzjarvis@hzjarvis-desktop:~$ systemctl status nvargus-daemon
● nvargus-daemon.service - Argus daemon
Loaded: loaded (/etc/systemd/system/nvargus-daemon.service; enabled; vendo>
Active: active (running) since Sun 2025-12-14 21:06:09 CET; 13h ago
Main PID: 1010 (nvargus-daemon)
Tasks: 1 (limit: 8810)
Memory: 103.8M
CPU: 265ms
CGroup: /system.slice/nvargus-daemon.service
└─1010 /usr/sbin/nvargus-daemon
dec 15 10:57:02 hzjarvis-desktop nvargus-daemon[1010]: (NvOdmDevice) Error Modu>
dec 15 10:57:02 hzjarvis-desktop nvargus-daemon[1010]: NvPclDriverInitializeDat>
dec 15 10:57:02 hzjarvis-desktop nvargus-daemon[1010]: NvPclInitializeDrivers: >
dec 15 10:57:02 hzjarvis-desktop nvargus-daemon[1010]: NvPclStartPlatformDriver>
dec 15 10:57:02 hzjarvis-desktop nvargus-daemon[1010]: NvPclStateControllerOpen>
dec 15 10:57:02 hzjarvis-desktop nvargus-daemon[1010]: NvPclOpen: PCL Open Fail>
dec 15 10:57:02 hzjarvis-desktop nvargus-daemon[1010]: SCF: Error BadParameter:>
lines 1-20/20 (END)
Since this camera gives the core functionality of my university project with a very tight deadline, I would really appreciate any help as soon as possible. :)
