请问 PCN21161的模组,有JetPack5.1.3的补丁吗?
是这样的,我们使用的JetPack5.1.3版本,目前因为业务导致暂时无法升级到JetPack5.1.4,但是我看到手册上说要升级到JetPack5.1.4才可以,请问有补丁或者更好的方法吗?
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
Suggest to contact your local distributor for your requirements.
