Hi
I’m currently trying to run RGMII 1G Ethernet on the Orin Jetson linux R36.2 Custom board.
Referring to the Jetson linux R36.2 Jetson Module Adaptation AndBringUp document, I set up RGMII.
My current setting status is as follows.
- Setting pinmux using Orin_Jetson_Series_Pinmux_Config_Template.xml
tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi
tegra234-mb1-bct-gpio-p3701-0000-a04.dtsi
- tegra234-mb1-bct-gpio-p3701-0000-a04.txt (3.4 KB)
PINMUX_CONFIG Settings in the p3701.conf.common File
PINMUX_CONFIG=“tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi”;
Check the pinmux value by referring to the JetsonModuleAdaptationAndBringUp document FORGMII.
- DT File
- tegra234-p3737-0000+p3701-0000.txt (16.4 KB)
Flash
After booting, the dmesg error message is as follows.
And the G4 and G5 values are as follows (sudokat/sys/ kernel/debug/gpio | grep PG.05)
I think G4 and G5 GPIO are not set up properly, so there is an nethernet error.
Why is there an Ethernet interface error?
