how can I upgrade Jetpack on a fused device without reflashing ?
Please refer to Image based OTA update method mentioned in below doc.
It is not possible to go through apt-server method since this is fused board.
your documentation mentions:
" You cannot use OTA update to update a Jetson device on which Jetpack is installed.
To update JetPack and Jetson Linux components to a new JetPack release on a system where both are installed, see the instructions in the JetPack documentation."
According to this statement it seems that OTA wouldn’t work ?
I asked you to check Image base OTA. Not Apt server OTA update.
These two are different methods.
