Hi all,
I am getting an “out of memory error” when loalding assets in the scene. I am loading a lot of assets, but I thought this simulator was meant for that after all we can see entire cities loaded in the Siggraph demo. Is there something that I should set in the rendering options ?
In this scene I have about 3000 unique assets that weight around 1Mb each.
I am running on Ryzen 5900HX with 32Gb of RAM and a 3070 with 8Gb of RAM.
Thanks in advance,
Antoine
2021-08-19 15:07:17 [309,003ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_OUT_OF_DEVICE_MEMORY
2021-08-19 15:07:17 [309,003ms] [Error] [carb.graphics-vulkan.plugin] vkAllocateMemory failed for flags: 0.
World0.usd@ <0x7f2c7c007bd0>)
2021-08-19 15:06:43 [274,870ms] [Warning] [omni.usd] Warning: in _ReportErrors at line 2830 of /buildAgent/work/ca6c508eae419cf8/USD/pxr/usd/usd/stage.cpp -- Could not open asset @omniverse://localhost/Isaac/Props/lake/dem_chunks/2_converted/8144_stl.usd@ for reference on prim @anon:0x7f2c7c002210:World0.usd@,@anon:0x7f2c7c0047c0:World0-session.usda@</World/lake_bed/lake_bed_2319>. (recomposing stage on stage @anon:0x7f2c7c002210:World0.usd@ <0x7f2c7c007bd0>)
2021-08-19 15:07:17 [309,010ms] [Error] [gpu.foundation.plugin] AccelStruct creation failed for the device: 0.
2021-08-19 15:07:17 [309,010ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_OUT_OF_DEVICE_MEMORY
2021-08-19 15:07:17 [309,166ms] [Error] [carb.graphics-vulkan.plugin] vkAllocateMemory failed for flags: 0.
2021-08-19 15:07:17 [309,167ms] [Error] [gpu.foundation.plugin] AccelStruct creation failed for the device: 0.
2021-08-19 15:07:17 [309,167ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_OUT_OF_DEVICE_MEMORY
2021-08-19 15:07:17 [309,167ms] [Error] [carb.graphics-vulkan.plugin] vkAllocateMemory failed for flags: 0.
2021-08-19 15:07:17 [309,168ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_OUT_OF_DEVICE_MEMORY
2021-08-19 15:07:17 [309,168ms] [Error] [carb.graphics-vulkan.plugin] vkAllocateMemory failed for flags: 0.
2021-08-19 15:07:17 [309,168ms] [Error] [gpu.foundation.plugin] subAllocate() failed for device 0, Buffer size: 162816
2021-08-19 15:07:17 [309,169ms] [Error] [carb.graphics-vulkan.plugin] vkAllocateMemory failed for flags: 0.
2021-08-19 15:07:17 [309,169ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_OUT_OF_DEVICE_MEMORY
2021-08-19 15:07:17 [309,170ms] [Error] [carb.graphics-vulkan.plugin] vkAllocateMemory failed for flags: 0.
2021-08-19 15:07:17 [309,170ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_OUT_OF_DEVICE_MEMORY
2021-08-19 15:07:17 [309,171ms] [Error] [gpu.foundation.plugin] AccelStruct creation failed for the device: 0.
2021-08-19 15:07:17 [309,171ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_OUT_OF_DEVICE_MEMORY
2021-08-19 15:07:17 [309,171ms] [Error] [carb.graphics-vulkan.plugin] vkAllocateMemory failed for flags: 0.
2021-08-19 15:07:17 [309,172ms] [Error] [gpu.foundation.plugin] AccelStruct creation failed for the device: 0.
2021-08-19 15:07:17 [309,172ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_OUT_OF_DEVICE_MEMORY
2021-08-19 15:07:17 [309,172ms] [Error] [carb.graphics-vulkan.plugin] vkAllocateMemory failed for flags: 0.
2021-08-19 15:07:17 [309,300ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_OUT_OF_DEVICE_MEMORY
2021-08-19 15:07:17 [309,300ms] [Error] [carb.graphics-vulkan.plugin] vkAllocateMemory failed for flags: 0.
2021-08-19 15:07:17 [309,300ms] [Error] [gpu.foundation.plugin] subAllocate() failed for device 0, Buffer size: 370368
2021-08-19 15:07:17 [309,304ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_OUT_OF_DEVICE_MEMORY
2021-08-19 15:07:17 [309,304ms] [Error] [carb.graphics-vulkan.plugin] vkAllocateMemory failed for flags: 0.
2021-08-19 15:07:17 [309,304ms] [Error] [gpu.foundation.plugin] subAllocate() failed for device 0, Buffer size: 318696
2021-08-19 15:07:17 [309,305ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_OUT_OF_DEVICE_MEMORY
2021-08-19 15:07:17 [309,305ms] [Error] [carb.graphics-vulkan.plugin] vkAllocateMemory failed for flags: 0.
2021-08-19 15:07:17 [309,305ms] [Error] [gpu.foundation.plugin] subAllocate() failed for device 0, Buffer size: 368112
2021-08-19 15:07:17 [309,306ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_OUT_OF_DEVICE_MEMORY
2021-08-19 15:07:17 [309,306ms] [Error] [carb.graphics-vulkan.plugin] vkAllocateMemory failed for flags: 0.
2021-08-19 15:07:17 [309,306ms] [Error] [gpu.foundation.plugin] subAllocate() failed for device 0, Buffer size: 142056
