Hardware Platform -Jetson Nano
DeepStream Version - 6.0.1
JetPack Version- 4.6.1
I am working on a project to detect people using nvdsanalytics.
My nvdsanalytics config is as follows, (my_roifiltering_config.txt)
[property]
enable=1
config-width=1920
config-height=1080
osd-mode=2
osd-display-font-size=12
[overcrowding-stream-0]
enable=1
roi-OC1=306;121;915;132;1047;960;15;893
object-threshold=3
#line-width=5
class-id=2
[overcrowding-stream-1]
enable=1
object-threshold=3
#border-width=5
class-id=2
According to the guide, only objects within the coordinates of roi-OC1 should be detected, but all objects within the entire screen (1920x1080) are detected.
Here is my deepstream-app setup.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=0
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
uri=rtsp://my_caemra url~
num-sources=1
#drop-frame-interval=2
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=5
sync=1
source-id=0
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=out.mp4
source-id=0
[sink2]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=0
batch-size=1
batched-push-timeout=40000
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
model-engine-file=../models/Primary_Detector_Nano/resnet10.caffemodel_b1_gpu0_fp16.engine
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=4
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_nano.txt
[tracker]
enable=1
tracker-width=640
tracker-height=384
ll-lib-file=/opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_nvmultiobjecttracker.so
ll-config-file required to set different tracker types
ll-config-file=config_tracker_IOU.yml
ll-config-file=config_tracker_NvDCF_perf.yml
ll-config-file=config_tracker_NvDCF_accuracy.yml
ll-config-file=config_tracker_DeepSORT.yml
gpu-id=0
enable-batch-process=1
enable-past-frame=1
display-tracking-id=1
[nvds-analytics]
enable=1
config-file=my_roifiltering_config.txt
[tests]
file-loop=1
Please help me.
