Hello! I think the EEPROM on one of my Jetson TX2NX’s has died because when I am trying to flash it, I receive this error. When I’m trying to flash other TX2NX’s everything works fine. I would like to know, what does this EEPROM part exactly do and how do I test the EEPROM via userspace or something? Can I force the flash script to ignore EEPROM during flash?
[ 2.3320 ] Retrieving EEPROM data
[ 2.3324 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/matiss/TX2NX/nvidia_sdk/Linux_for_Tegra/bootloader/cvm.bin
[ 2.3367 ] Applet version 01.00.0000
[ 2.6144 ] Saved platform info in /home/matiss/TX2NX/nvidia_sdk/Linux_for_Tegra/bootloader/cvm.bin
[ 2.7609 ]
Parsing board information failed.
Is that TX2-NX module still able to boot up? I mean boot into linux.
Please use i2cdump to dump the i2c bus with address 0x50.
I don’t have a TX2-NX now to check which bus is for the module eeprom, you can just scan each bus.
Here’s the dump on i2c-7
I will probe file /dev/i2c-7, address 0x50, mode byte
Continue? [Y/n]
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 01 00 0d 00 34 0e 01 00 03 48 00 00 00 00 00 00 ?.?.4??.?H......
10: 00 01 00 00 36 39 39 2d 31 33 36 33 36 2d 30 30 .?..699-13636-00
20: 30 31 2d 33 30 30 20 48 2e 30 00 00 00 00 00 00 01-300 H.0......
30: 00 00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
40: ff ff ff ff 44 34 3b 2d b0 48 31 34 32 30 35 32 ....D4;-?H142052
50: 31 30 31 34 36 32 36 00 00 00 00 00 00 00 00 00 1014626.........
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
90: 00 00 00 00 00 00 4e 56 43 42 1c 00 4d 31 00 00 ......NVCB?.M1..
a0: ff ff ff ff ff ff ff ff ff ff ff ff 44 34 3b 2d ............D4;-
b0: b0 48 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ?H..............
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 af ...............?
Then looks like the eeprom is still here.
Please go back to flash.sh, dump the uart log when flash.sh gives out error.
I have disabled the UART logs from bootloader as I have a device connected to that UART, so that won’t be an option at the moment.
However, here’s a dump of the EEPROM from different module:
30: 00 00 ff ff ff 34 ff ff ff ff ff ff ff ff ff ff .....4..........
40: ff ff ff ff ed 33 3b 2d b0 48 31 34 32 30 35 32 ....?3;-?H142052
50: 31 30 31 33 39 39 39 00 00 00 00 00 00 00 00 00 1013999.........
a0: ff ff ff ff ff ff ff ff ff ff ff ff ed 33 3b 2d ............?3;-
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0f ...............?
It is pointless to compare the eeprom between different modules directly.
If you cannot dump flash log, then I cannot help you.
But could you explain - what does exactly .flash.sh do with the EEPROM? I checked in flash.py that there’s this:
chkerr "Reading board information failed.";
if [ "${SKIP_EEPROM_CHECK}" = "" ]; then
boardid=`./chkbdinfo -i cvm.bin`;
boardversion=`./chkbdinfo -f cvm.bin`;
boardsku=`./chkbdinfo -k cvm.bin`;
boardrevision=`./chkbdinfo -r cvm.bin`;
chkerr "Parsing board information failed.";
fi;
You can try to enable that. Maybe it would pass.
Make it easier to understand, flash script needs eeprom info to know which board is in use.
Okay, right now I tried and it seems commenting it out, the flash works fine? Basically I only have to be sure that I am using correct board as the flash argument. I suppose the SKIP_EEPROM_CHECK
is not implemented as an argument yet.
If you skip the eeprom, then you need to give boardid,boardversion,boardsku and boardrevision manually.
system
Closed
May 5, 2022, 11:36am
13
