I am developing a carrier card for Jetson nano. There are two ethernet on my card. I am using INTEL82574L ethernet PHY for someone. How can I install DRIVER for this ethernet?
Please check whether Intel provides the ubuntu driver in arm64 arch or not.
hi,
Does JETSON NANO MODULE have different systems with the TX1 card? Because this Ethernet PHY is used in ASTRO CARRIER BOARD.
Jetson nano is using TX1 soc but different carrier board and also some configuration are different from TX1 so that it is not compatible directly.
I am not sure what PHY is in use on Astro board. If they need extra driver, then you still need to install it.
