We install an external pcie wifi module on tx2. If we don’t change anything with dtb. We can ping network. But when use scp to transfer too large file (over than 1G) we get arm-smmu issue. Just like https://devtalk.nvidia.com/default/topic/1035808/jetson-tx2/altera-fpga-dma-to-tx2-via-pcie-problem/. After follow the instruction to disable smmu component (through change dtb), after boot up, I have bellow error message. Can somebody meet such kind of issue before?
[ 35.356379] hif_pci_probe: ramdump base 0xffffffc1dda00000 size 2095136
[ 35.368471] R0: wlan: [1045:E :HDD] hdd_apply_cfg_ini: Reg Parameter gRrmOperChanMax > allowed Maximum [8 > 7]. Enforcing Default= 4
[ 35.382876] R0: wlan: [1045:E :HDD] hdd_apply_cfg_ini: Reg Parameter gRrmNonOperChanMax > allowed Maximum [8 > 7]. Enforcing Default= 4
[ 35.398800] R0: wlan: [1045:E :HDD] hdd_apply_cfg_ini: Reg Parameter gtsf_gpio_pin > allowed Maximum [255 > 254]. Enforcing Default= 255
[ 35.413618] R0: wlan: [1045:E :HDD] hdd_apply_cfg_ini: Reg Parameter 5g_rssi_boost_threshold < allowed Minimum [4294967236 < 18446744073709551546]. Enforcing Default= 18446744073709551556
[ 35.432728] R0: wlan: [1045:E :HDD] hdd_apply_cfg_ini: Reg Parameter 5g_rssi_penalize_threshold < allowed Minimum [4294967226 < 18446744073709551536]. Enforcing Default= 18446744073709551546
[ 35.452298] R0: wlan: [1045:E :HDD] Name = [gEnableHostapdEdcaLocal] Value = [0]
[ 35.461023] R0: wlan: [1045:E :HDD] Name = [g_sta_change_cc_via_beacon] Value = [0]
[ 35.470984] R0: [insmod][17:00:22.093996] wlan: [1045:E :HDD] Name = [gEnableHostapdEdcaLocal] Value = [0]
[ 35.482173] R0: [insmod][17:00:22.105186] wlan: [1045:E :HDD] Name = [g_sta_change_cc_via_beacon] Value = [0]
[ 35.499454] NUM_DEV=1 FWMODE=0x2 FWSUBMODE=0x0 FWBR_BUF 0
[ 35.509121] ol_download_firmware: Using 0x1234 for the remainder of init
[ 35.536659] R0: [insmod][17:00:22.159667] wlan: [1045:E :VOS] __ol_transfer_bin_file: transferring file: otp30.bin size 24209 bytes done!
[ 35.550600] ol_download_firmware: chip_id:0x5030000 board_id:0x0
[ 35.559331] Board extended Data download address: 0x0
[ 35.571375] R0: [insmod][17:00:22.194386] wlan: [1045:E :VOS] __ol_transfer_bin_file: transferring file: bdwlan30.bin size 8124 bytes done!
[ 35.585708] __ol_transfer_bin_file: no Setup file defined
[ 36.120760] R0: [insmod][17:00:22.743768] wlan: [1045:E :VOS] __ol_transfer_bin_file: transferring file: qwlan30.bin size 653005 bytes done!
[ 36.135179] +HTCCreate .. HIF :ffffffc1e23e1000
[ 36.141465] -HTCCreate (0xffffffc1e5b33000)
[ 36.147645] R0: [insmod][17:00:22.770656] wlan: [1045:F :WDA] WMA --> wmi_unified_attach - success
[ 36.158169] ol_if_dfs_attach: called; ptr=ffffffc1e0815fa8, radar_info=ffffffc1e0ee3628
[ 36.167867] R0: [insmod][17:00:22.790878] wlan: [1045:E :SAP] dfs_init_radar_filters[217]: Unknown dfs domain 0
[ 36.179634] send_filled_buffers_to_user: Send Failed -3 drop_count = 1
Segmentation fault
[ 36.179660] +HWT
[ 36.179663] pipe_num:0 pipe_info:0xffffffc1e23e10b8
worker@master:~$ [ 36.179703] pipe_num:3 pipe_info:0xffffffc1e23e1220
[ 36.179712] pipe_num:4 pipe_info:0xffffffc1e23e1298
[ 36.179777] Unable to handle kernel paging request at virtual address ffffffbfe08cf600
[ 36.179778] pgd = ffffffc1e4b12000
[ 36.179781] [ffffffbfe08cf600] *pgd=0000000000000000, *pud=0000000000000000
[ 36.179784] Internal error: Oops: 96000146 [#1] PREEMPT SMP
[ 36.179793] Modules linked in: wlan(+) ipt_MASQUERADE nf_nat_masquerade_ipv4 iptable_nat nf_nat_ipv4 nf_nat iptable_filter ip_tables pci_tegra bluedroid_pm
[ 36.179796] CPU: 5 PID: 1045 Comm: insmod Not tainted 4.4.38+ #2
[ 36.179797] Hardware name: quill (DT)
[ 36.179799] task: ffffffc1e2063200 ti: ffffffc1e0ee0000 task.ti: ffffffc1e0ee0000
[ 36.179805] PC is at __dma_inv_range+0x38/0x50
[ 36.179808] LR is at arm_dma_sync_single_for_device+0x2c/0x38
[ 36.179809] pc : [<ffffffc00009a6a8>] lr : [<ffffffc000095264>] pstate: 40000045
[ 36.179810] sp : ffffffc1e0ee3620
[ 36.179812] x29: ffffffc1e0ee3620 x28: ffffffc1e2b26600
[ 36.179814] x27: 00000000608cf600 x26: ffffffc1e2859e00
[ 36.179816] x25: 00000000f005ba11 x24: 0000000000000000
[ 36.179818] x23: 0000000000000800 x22: ffffffc1e23e1158
[ 36.179819] x21: ffffffc07b398800 x20: ffffffc1e23e1148
[ 36.179821] x19: ffffffc1e23e1130 x18: 00000000fffffff0
[ 36.179822] x17: 0000000000000000 x16: 000000000002e7a0
[ 36.179824] x15: ffffffc001298858 x14: ffffffc00143dbd8
[ 36.179826] x13: ffffffc001298000 x12: ffffffc00143c000
[ 36.179827] x11: 0000000000000000 x10: 0000000000000068
[ 36.179829] x9 : 0000000000000000 x8 : ffffffc000095270
[ 36.179830] x7 : ffffffc1e200c098 x6 : ffffffc1e08cf600
[ 36.179832] x5 : ffffffc00127f000 x4 : 0000000000000800
[ 36.179833] x3 : 000000000000003f x2 : 0000000000000040
[ 36.179835] x1 : ffffffbfe08cfe00 x0 : ffffffbfe08cf600
[ 36.179835]
[ 36.179837] Process insmod (pid: 1045, stack limit = 0xffffffc1e0ee0020)
[ 36.179838] Call trace:
[ 36.179840] [<ffffffc00009a6a8>] __dma_inv_range+0x38/0x50
[ 36.180440] [<ffffffbffc289288>] hif_post_recv_buffers_for_pipe+0x118/0x4f0 [wlan]
[ 36.181220] [<ffffffbffc2896b4>] hif_post_recv_buffers+0x54/0x88 [wlan]
[ 36.181854] [<ffffffbffc28b12c>] HIFStart+0x5c/0x128 [wlan]
[ 36.182420] [<ffffffbffc27f9f0>] HTCWaitTarget+0x30/0x278 [wlan]
[ 36.182977] [<ffffffbffc205684>] vos_open+0x4a4/0x8f0 [wlan]
[ 36.183513] [<ffffffbffc087514>] hdd_wlan_startup+0x67c/0x1f50 [wlan]
[ 36.184065] [<ffffffbffc2901e4>] hif_pci_probe+0x644/0x7e0 [wlan]
[ 36.184072] [<ffffffc000394918>] pci_device_probe+0xa0/0x118
[ 36.184076] [<ffffffc000589424>] driver_probe_device+0xcc/0x408
[ 36.184078] [<ffffffc0005897fc>] __driver_attach+0x9c/0xa0
[ 36.184081] [<ffffffc000587334>] bus_for_each_dev+0x64/0xa0
[ 36.184083] [<ffffffc000588d20>] driver_attach+0x20/0x28
[ 36.184085] [<ffffffc000588850>] bus_add_driver+0x1d0/0x298
[ 36.184088] [<ffffffc00058a5e0>] driver_register+0x60/0xf8
[ 36.184090] [<ffffffc000393700>] __pci_register_driver+0x38/0x40
[ 36.184657] [<ffffffbffc28fb00>] hif_register_driver+0x18/0x38 [wlan]
[ 36.185197] [<ffffffbffc07ae80>] hdd_hif_register_driver+0x30/0x120 [wlan]
[ 36.185714] [<ffffffbffc5f2104>] hdd_module_init+0x104/0x230 [wlan]
[ 36.185718] [<ffffffc000081c70>] do_one_initcall+0xd0/0x1d8
[ 36.185722] [<ffffffc00017084c>] do_init_module+0x64/0x1b0
[ 36.185726] [<ffffffc000122a88>] load_module+0xec0/0x11b8
[ 36.185727] [<ffffffc000123008>] SyS_finit_module+0xc8/0xf8
[ 36.185730] [<ffffffc000084ff0>] el0_svc_naked+0x24/0x28
[ 36.185948] ---[ end trace d9f04c3ecf264a17 ]---
