Performance goes down when our kernel function runs on Xavier compared to GeForce 940MX
Our kernel function costs approximate 2.90ms on GeForce 940MX.
Howerver,on Xavier time-cost remain between 5.45ms-5.78ms no matter how the grid and block size arrangement change
It’s seems that Xavier is more powerful than GeForce 940MX , so it does’t make sense to get this result. What’s could be wrong?
GeForce 940MX device properties:
./deviceQuery Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "GeForce 940MX"
  CUDA Driver Version / Runtime Version          9.1 / 9.0
  CUDA Capability Major/Minor version number:    5.0
  Total amount of global memory:                 2004 MBytes (2101870592 bytes)
  ( 3) Multiprocessors, (128) CUDA Cores/MP:     384 CUDA Cores
  GPU Max Clock rate:                            1189 MHz (1.19 GHz)
  Memory Clock rate:                             2505 Mhz
  Memory Bus Width:                              64-bit
  L2 Cache Size:                                 1048576 bytes
  Maximum Texture Dimension Size (x,y,z)         1D=(65536), 2D=(65536, 65536), 3D=(4096, 4096, 4096)
  Maximum Layered 1D Texture Size, (num) layers  1D=(16384), 2048 layers
  Maximum Layered 2D Texture Size, (num) layers  2D=(16384, 16384), 2048 layers
  Total amount of constant memory:               65536 bytes
  Total amount of shared memory per block:       49152 bytes
  Total number of registers available per block: 65536
  Warp size:                                     32
  Maximum number of threads per multiprocessor:  2048
  Maximum number of threads per block:           1024
  Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
  Max dimension size of a grid size    (x,y,z): (2147483647, 65535, 65535)
  Maximum memory pitch:                          2147483647 bytes
  Texture alignment:                             512 bytes
  Concurrent copy and kernel execution:          Yes with 1 copy engine(s)
  Run time limit on kernels:                     No
  Integrated GPU sharing Host Memory:            No
  Support host page-locked memory mapping:       Yes
  Alignment requirement for Surfaces:            Yes
  Device has ECC support:                        Disabled
  Device supports Unified Addressing (UVA):      Yes
  Supports Cooperative Kernel Launch:            No
  Supports MultiDevice Co-op Kernel Launch:      No
  Device PCI Domain ID / Bus ID / location ID:   0 / 2 / 0
  Compute Mode:
     < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 9.1, CUDA Runtime Version = 9.0, NumDevs = 1
Result = PASS
Xavier device properties:
Device 0: "Xavier"
  CUDA Driver Version / Runtime Version          10.0 / 10.0
  CUDA Capability Major/Minor version number:    7.2
  Total amount of global memory:                 15819 MBytes (16587653120 bytes)
  ( 8) Multiprocessors, ( 64) CUDA Cores/MP:     512 CUDA Cores
  GPU Max Clock rate:                            1500 MHz (1.50 GHz)
  Memory Clock rate:                             1500 Mhz
  Memory Bus Width:                              256-bit
  L2 Cache Size:                                 524288 bytes
  Maximum Texture Dimension Size (x,y,z)         1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
  Maximum Layered 1D Texture Size, (num) layers  1D=(32768), 2048 layers
  Maximum Layered 2D Texture Size, (num) layers  2D=(32768, 32768), 2048 layers
  Warp size:                                     32
  Integrated GPU sharing Host Memory:            Yes
  Device supports Compute Preemption:            Yes
  Supports Cooperative Kernel Launch:            Yes
  Supports MultiDevice Co-op Kernel Launch:      Yes
  Device PCI Domain ID / Bus ID / location ID:   0 / 0 / 0
  Compute Mode:
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 10.0, CUDA Runtime Version = 10.0, NumDevs = 1
Result = PASS
Have you maximized the device performance first?
sudo jetson_clocks
Yes,we did.
We found that it’s may be caused by the low efficiency of the SIMD instruction “__vsadu4” that we used in the code.
We did the the following substitution test:
We replaced the __vsadu4 instruction with __vsub4 instruction and got a reversal.
6.41 ms on GeForce 940MX
1.76 ms on Xavier
The result seems to be inconsistent with the instruction-throughput table https://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#maximize-instruction-throughput
Please check this issue.
Another possible issue the compiling option.
Have you specified the Xavier capacity when compiling? Xavier is sm=72.
Yes,we have.
Actually, We digged out more details using cuobjdump tool.
Firstly, Let’s see the SAD dump
__vsadu4 code:
__global__ void usad4Cmbn(unsigned int *A, unsigned int *B, unsigned int *C)
             C[threadIdx.x]=__vsadu4(A[threadIdx.x],B[threadIdx.x]);
__vsadu4 dump:
code for sm_30
  Function : _Z9usad4CmbnPjS_S_
 .headerflags    @""EF_CUDA_SM30 EF_CUDA_PTX_SM(EF_CUDA_SM30)""
        /* 0x22c04282c2804307 */
        /*0008*/                   MOV R1, c[0x0][0x44];                         /* 0x2800400110005de4 */
        /*0010*/                   S2R R0, SR_TID.X;                             /* 0x2c00000084001c04 */
        /*0018*/                   MOV32I R7, 0x4;                               /* 0x180000001001dde2 */
        /*0020*/                   ISCADD R2.CC, R0, c[0x0][0x140], 0x2;         /* 0x4001400500009c43 */
        /*0028*/                   IMAD.U32.U32.HI.X R3, R0, R7, c[0x0][0x144];  /* 0x208e80051000dc43 */
        /*0030*/                   ISCADD R4.CC, R0, c[0x0][0x148], 0x2;         /* 0x4001400520011c43 */
        /*0038*/                   LD.E R2, [R2];                                /* 0x8400000000209c85 */
        /* 0x22f04283f2c04287 */
        /*0048*/                   IMAD.U32.U32.HI.X R5, R0, R7, c[0x0][0x14c];  /* 0x208e800530015c43 */
        /*0050*/                   LD.E R4, [R4];                                /* 0x8400000000411c85 */
        /*0058*/                   ISCADD R6.CC, R0, c[0x0][0x150], 0x2;         /* 0x4001400540019c43 */
        /*0060*/                   IMAD.U32.U32.HI.X R7, R0, R7, c[0x0][0x154];  /* 0x208e80055001dc43 */
        /*0068*/                   VABSDIFF4.U8.U8.ACC R0, R2, R4, RZ;           /* 0x89fec44c10201c04 */
        /*0070*/                   ST.E [R6], R0;                                /* 0x9400000000601c85 */
        /*0078*/                   EXIT;                                         /* 0x8000000000001de7 */
        /*0080*/                   BRA 0x80;                                     /* 0x4003ffffe0001de7 */
        /*0088*/                   NOP;                                          /* 0x4000000000001de4 */
        /*0090*/                   NOP;                                          /* 0x4000000000001de4 */
        /*0098*/                   NOP;                                          /* 0x4000000000001de4 */
        /*00a0*/                   NOP;                                          /* 0x4000000000001de4 */
        /*00a8*/                   NOP;                                          /* 0x4000000000001de4 */
        /*00b0*/                   NOP;                                          /* 0x4000000000001de4 */
        /*00b8*/                   NOP;                                          /* 0x4000000000001de4 */
Fatbin elf code:
arch = sm_35
code version = [1,7]
producer = cuda
host = linux
compile_size = 64bit
 code for sm_35
 .headerflags    @""EF_CUDA_SM35 EF_CUDA_PTX_SM(EF_CUDA_SM35)""
        /* 0x08b010a0b0a010c0 */
        /*0008*/                   MOV R1, c[0x0][0x44];                         /* 0x64c03c00089c0006 */
        /*0010*/                   S2R R0, SR_TID.X;                             /* 0x86400000109c0002 */
        /*0018*/                   MOV32I R7, 0x4;                               /* 0x74000000021fc01e */
        /*0020*/                   ISCADD R2.CC, R0, c[0x0][0x140], 0x2;         /* 0x60c40800281c000a */
        /*0028*/                   IMAD.U32.U32.HI.X R3, R0, R7, c[0x0][0x144];  /* 0x92101c00289c000e */
        /*0030*/                   ISCADD R4.CC, R0, c[0x0][0x148], 0x2;         /* 0x60c40800291c0012 */
        /*0038*/                   LD.E R2, [R2];                                /* 0xc4800000001c0808 */
        /* 0x08bc10a0fcb010a0 */
        /*0048*/                   IMAD.U32.U32.HI.X R5, R0, R7, c[0x0][0x14c];  /* 0x92101c00299c0016 */
        /*0050*/                   LD.E R4, [R4];                                /* 0xc4800000001c1010 */
        /*0058*/                   ISCADD R6.CC, R0, c[0x0][0x150], 0x2;         /* 0x60c408002a1c001a */
        /*0060*/                   IMAD.U32.U32.HI.X R7, R0, R7, c[0x0][0x154];  /* 0x92101c002a9c001e */
        /*0068*/                   VABSDIFF4.U8.U8.ACC R0, R2, R4, RZ;           /* 0x81c3fda2021c0802 */
        /*0070*/                   ST.E [R6], R0;                                /* 0xe4800000001c1800 */
        /*0078*/                   EXIT;                                         /* 0x18000000001c003c */
        /*0080*/                   BRA 0x80;                                     /* 0x12007ffffc1c003c */
        /*0088*/                   NOP;                                          /* 0x85800000001c3c02 */
        /*0090*/                   NOP;                                          /* 0x85800000001c3c02 */
        /*0098*/                   NOP;                                          /* 0x85800000001c3c02 */
        /*00a0*/                   NOP;                                          /* 0x85800000001c3c02 */
        /*00a8*/                   NOP;                                          /* 0x85800000001c3c02 */
        /*00b0*/                   NOP;                                          /* 0x85800000001c3c02 */
        /*00b8*/                   NOP;                                          /* 0x85800000001c3c02 */
Fatbin elf code:
arch = sm_37
producer = cuda
host = linux
 code for sm_37
 .headerflags    @""EF_CUDA_SM37 EF_CUDA_PTX_SM(EF_CUDA_SM37)""
Fatbin elf code:
arch = sm_50
producer = cuda
host = linux
 code for sm_50
 .headerflags    @""EF_CUDA_SM50 EF_CUDA_PTX_SM(EF_CUDA_SM50)""
        /* 0x083fc400e3e007f6 */
        /*0008*/                   MOV R1, c[0x0][0x20] ;                 /* 0x4c98078000870001 */
        /*0010*/                   S2R R0, SR_TID.X ;                     /* 0xf0c8000002170000 */
        /*0018*/                   SHL R6, R0.reuse, 0x2 ;                /* 0x3848000000270006 */
        /* 0x081fc840fec007f5 */
        /*0028*/                   SHR.U32 R0, R0, 0x1e ;                 /* 0x3828000001e70000 */
        /*0030*/                   IADD R2.CC, R6.reuse, c[0x0][0x140] ;  /* 0x4c10800005070602 */
        /*0038*/                   IADD.X R3, R0.reuse, c[0x0][0x144] ;   /* 0x4c10080005170003 */
        /* 0x001f8800fec007f0 */
        /*0048*/         {         IADD R4.CC, R6, c[0x0][0x148] ;        /* 0x4c10800005270604 */
        /*0050*/                   LDG.E R2, [R2]         }
        /* 0xeed4200000070202 */
        /*0058*/                   IADD.X R5, R0, c[0x0][0x14c] ;         /* 0x4c10080005370005 */
        /* 0x001fdc00fec007b1 */
        /*0068*/                   LDG.E R4, [R4] ;                       /* 0xeed4200000070404 */
        /*0070*/                   IADD R6.CC, R6, c[0x0][0x150] ;        /* 0x4c10800005470606 */
        /*0078*/                   IADD.X R7, R0, c[0x0][0x154] ;         /* 0x4c10080005570007 */
        /* 0x001ffc00fe2107f2 */
        /*0088*/                   VABSDIFF4.U8.U8.ACC R0, R2, R4, RZ ;   /* 0x50387fb440470200 */
        /*0090*/                   STG.E [R6], R0 ;                       /* 0xeedc200000070600 */
        /*0098*/                   EXIT ;                                 /* 0xe30000000007000f */
        /* 0x001f8000fc0007ff */
        /*00a8*/                   BRA 0xa0 ;                             /* 0xe2400fffff07000f */
        /*00b0*/                   NOP;                                   /* 0x50b0000000070f00 */
        /*00b8*/                   NOP;                                   /* 0x50b0000000070f00 */
Fatbin elf code:
arch = sm_52
producer = cuda
host = linux
 code for sm_52
 .headerflags    @""EF_CUDA_SM52 EF_CUDA_PTX_SM(EF_CUDA_SM52)""
Fatbin elf code:
arch = sm_60
producer = cuda
host = linux
 code for sm_60
 .headerflags    @""EF_CUDA_SM60 EF_CUDA_PTX_SM(EF_CUDA_SM60)""
        /* 0x001f8800fcc007e5 */
        /*0030*/                   IADD R2.CC, R6, c[0x0][0x140] ;       /* 0x4c10800005070602 */
        /*0038*/                   IADD.X R3, R0, c[0x0][0x144] ;        /* 0x4c10080005170003 */
        /* 0x001fdc00fcc007b1 */
        /* 0x001ffc00fe2107e2 */
Fatbin elf code:
arch = sm_61
producer = cuda
host = linux
 code for sm_61
 .headerflags    @""EF_CUDA_SM61 EF_CUDA_PTX_SM(EF_CUDA_SM61)""
Fatbin elf code:
arch = sm_70
producer = cuda
host = linux
 code for sm_70
 .headerflags    @""EF_CUDA_SM70 EF_CUDA_PTX_SM(EF_CUDA_SM70)""
        /*0000*/                   IMAD.MOV.U32 R1, RZ, RZ, c[0x0][0x28] ;                /* 0x00000a00ff017624 */
        /* 0x000fd000078e00ff */
        /*0010*/              @!PT SHFL.IDX PT, RZ, RZ, RZ, RZ ;                          /* 0x000000fffffff389 */
        /* 0x000fe200000e00ff */
        /*0020*/                   S2R R2, SR_TID.X ;                                     /* 0x0000000000027919 */
        /* 0x000e220000002100 */
        /*0030*/                   IMAD.MOV.U32 R0, RZ, RZ, 0x4 ;                         /* 0x00000004ff007424 */
        /* 0x000fc800078e00ff */
        /*0040*/                   IMAD.WIDE.U32 R4, R2.reuse, R0.reuse, c[0x0][0x160] ;  /* 0x0000580002047625 */
        /* 0x0c1fe400078e0000 */
        /*0050*/                   IMAD.WIDE.U32 R6, R2, R0, c[0x0][0x168] ;              /* 0x00005a0002067625 */
        /* 0x000fd000078e0000 */
        /*0060*/                   LDG.E.SYS R4, [R4] ;                                   /* 0x0000000004047381 */
        /* 0x000ea800001ee900 */
        /*0070*/                   LDG.E.SYS R6, [R6] ;                                   /* 0x0000000006067381 */
        /* 0x000ea400001ee900 */
        /*0080*/                   PRMT R3, R4.reuse, 0x3210, R6.reuse ;                  /* 0x0000321004037816 */
        /* 0x144fe40000000006 */
        /*0090*/                   PRMT R8, R4, 0x7654, R6 ;                              /* 0x0000765404087816 */
        /* 0x000fe40000000006 */
        /*00a0*/                   PRMT R9, R3, 0x7650, RZ ;                              /* 0x0000765003097816 */
        /* 0x000fc400000000ff */
        /*00b0*/                   PRMT R12, R8.reuse, 0x7650, RZ ;                       /* 0x00007650080c7816 */
        /* 0x040fe400000000ff */
        /*00c0*/                   PRMT R10, R3.reuse, 0x7651, RZ ;                       /* 0x00007651030a7816 */
        /*00d0*/                   PRMT R11, R3, 0x7652, RZ ;                             /* 0x00007652030b7816 */
        /* 0x000fe200000000ff */
        /*00e0*/                   IMAD.IADD R9, R9, 0x1, -R12 ;                          /* 0x0000000109097824 */
        /* 0x000fe200078e0a0c */
        /*00f0*/                   PRMT R13, R8.reuse, 0x7651, RZ ;                       /* 0x00007651080d7816 */
        /*0100*/                   PRMT R14, R8, 0x7652, RZ ;                             /* 0x00007652080e7816 */
        /* 0x000fe400000000ff */
        /*0110*/                   PRMT R3, R3, 0x7653, RZ ;                              /* 0x0000765303037816 */
        /*0120*/                   IMAD.IADD R10, R10, 0x1, -R13 ;                        /* 0x000000010a0a7824 */
        /* 0x000fe200078e0a0d */
        /*0130*/                   PRMT R8, R8, 0x7653, RZ ;                              /* 0x0000765308087816 */
        /*0140*/                   IMAD.IADD R11, R11, 0x1, -R14 ;                        /* 0x000000010b0b7824 */
        /* 0x000fe200078e0a0e */
        /*0150*/                   IABS R9, R9 ;                                          /* 0x0000000900097213 */
        /* 0x000fc40000000000 */
        /*0160*/                   IABS R5, R10 ;                                         /* 0x0000000a00057213 */
        /* 0x000fe20000000000 */
        /*0170*/                   IMAD.IADD R3, R3, 0x1, -R8 ;                           /* 0x0000000103037824 */
        /* 0x000fe200078e0a08 */
        /*0180*/                   IABS R4, R11 ;                                         /* 0x0000000b00047213 */
        /* 0x000fc80000000000 */
        /*0190*/                   IABS R6, R3 ;                                          /* 0x0000000300067213 */
        /*01a0*/                   IMAD.MOV.U32 R3, RZ, RZ, R9 ;                          /* 0x000000ffff037224 */
        /* 0x000fca00078e0009 */
        /*01b0*/                   IADD3 R4, R4, R3, R5 ;                                 /* 0x0000000304047210 */
        /* 0x000fe20007ffe005 */
        /*01c0*/                   IMAD.WIDE.U32 R2, R2, R0, c[0x0][0x170] ;              /* 0x00005c0002027625 */
        /* 0x000fc800078e0000 */
        /*01d0*/                   IMAD.IADD R4, R4, 0x1, R6 ;                            /* 0x0000000104047824 */
        /* 0x000fd000078e0206 */
        /*01e0*/                   STG.E.SYS [R2], R4 ;                                   /* 0x0000000402007386 */
        /* 0x000fe2000010e900 */
        /*01f0*/                   EXIT ;                                                 /* 0x000000000000794d */
        /* 0x000fea0003800000 */
        /*0200*/                   BRA 0x200;                                             /* 0xfffffff000007947 */
        /* 0x000fc0000383ffff */
        /*0210*/                   NOP;                                                   /* 0x0000000000007918 */
        /* 0x000fc00000000000 */
        /*0220*/                   NOP;                                                   /* 0x0000000000007918 */
        /*0230*/                   NOP;                                                   /* 0x0000000000007918 */
        /*0240*/                   NOP;                                                   /* 0x0000000000007918 */
        /*0250*/                   NOP;                                                   /* 0x0000000000007918 */
        /*0260*/                   NOP;                                                   /* 0x0000000000007918 */
        /*0270*/                   NOP;                                                   /* 0x0000000000007918 */
Fatbin elf code:
arch = sm_72
producer = cuda
host = linux
 code for sm_72
 .headerflags    @""EF_CUDA_SM72 EF_CUDA_PTX_SM(EF_CUDA_SM72)""
        /*0100*/
Secondly ,I’d like to decompose the SAD operation into three SIMD instructions to share more info.
Subtraction code:
              C[threadIdx.x]=__vsub4(A[threadIdx.x],B[threadIdx.x]);
Subtraction dump:
arch = sm_30
producer = cuda
host = linux
	code for sm_30
	.headerflags    @"EF_CUDA_SM30 EF_CUDA_PTX_SM(EF_CUDA_SM30)"
        /*0068*/                   VADD4.UD.U8.U8 R0, R2, -R4, RZ;               /* 0x81fe844c10201c84 */
Fatbin elf code:
arch = sm_35
producer = cuda
host = linux
	code for sm_35
	.headerflags    @"EF_CUDA_SM35 EF_CUDA_PTX_SM(EF_CUDA_SM35)"
        /*0068*/                   VADD4.UD.U8.U8 R0, R2, -R4, RZ;               /* 0xd4c3fda2021c0801 */
Fatbin elf code:
arch = sm_37
producer = cuda
host = linux
	code for sm_37
	.headerflags    @"EF_CUDA_SM37 EF_CUDA_PTX_SM(EF_CUDA_SM37)"
Fatbin elf code:
arch = sm_50
producer = cuda
host = linux
	code for sm_50
	.headerflags    @"EF_CUDA_SM50 EF_CUDA_PTX_SM(EF_CUDA_SM50)"
        /*0028*/                   SHR.U32 R7, R0, 0x1e ;                    /* 0x3828000001e70007 */
        /*0038*/                   IADD.X R3, R7.reuse, c[0x0][0x144] ;      /* 0x4c10080005170703 */
        /* 0x001f8800f6c007f0 */
        /*0058*/                   IADD.X R5, R7, c[0x0][0x14c] ;            /* 0x4c10080005370705 */
        /*0078*/                   IADD.X R7, R7, c[0x0][0x154] ;            /* 0x4c10080005570707 */
        /* 0x001f9400fe2307f1 */
        /*0088*/                   LOP32I.OR R0, R2.reuse, 0x80808080 ;      /* 0x0428080808070200 */
        /*0090*/                   LOP32I.AND R9, R4, 0x7f7f7f7f ;           /* 0x0407f7f7f7f70409 */
        /*0098*/                   LOP3.LUT R8, R2, c[0x2][0x0], R4, 0x84 ;  /* 0x0284020800070208 */
        /* 0x001fc400fe4007f6 */
        /*00a8*/                   IADD R9, R0, -R9 ;                        /* 0x5c11000000970009 */
        /*00b0*/                   LOP.XOR R8, R9, R8 ;                      /* 0x5c47040000870908 */
        /*00b8*/                   STG.E [R6], R8 ;                          /* 0xeedc200000070608 */
        /* 0x001f8000ffe007ff */
        /*00c8*/                   EXIT ;                                    /* 0xe30000000007000f */
        /*00d0*/                   BRA 0xd0 ;                                /* 0xe2400fffff87000f */
        /*00d8*/                   NOP;                                      /* 0x50b0000000070f00 */
        /* 0x001f8000fc0007e0 */
        /*00e8*/                   NOP;                                      /* 0x50b0000000070f00 */
        /*00f0*/                   NOP;                                      /* 0x50b0000000070f00 */
        /*00f8*/                   NOP;                                      /* 0x50b0000000070f00 */
Fatbin elf code:
arch = sm_52
producer = cuda
host = linux
	code for sm_52
	.headerflags    @"EF_CUDA_SM52 EF_CUDA_PTX_SM(EF_CUDA_SM52)"
Fatbin elf code:
arch = sm_60
producer = cuda
host = linux
	code for sm_60
	.headerflags    @"EF_CUDA_SM60 EF_CUDA_PTX_SM(EF_CUDA_SM60)"
Fatbin elf code:
arch = sm_61
producer = cuda
host = linux
	code for sm_61
	.headerflags    @"EF_CUDA_SM61 EF_CUDA_PTX_SM(EF_CUDA_SM61)"
Fatbin elf code:
arch = sm_70
producer = cuda
host = linux
	code for sm_70
	.headerflags    @"EF_CUDA_SM70 EF_CUDA_PTX_SM(EF_CUDA_SM70)"
        /*0020*/                   S2R R7, SR_TID.X ;                                      /* 0x0000000000077919 */
        /*0030*/                   MOV R10, 0x4 ;                                          /* 0x00000004000a7802 */
        /* 0x000fca0000000f00 */
        /*0040*/                   IMAD.WIDE.U32 R2, R7.reuse, R10.reuse, c[0x0][0x160] ;  /* 0x0000580007027625 */
        /* 0x0c1fe400078e000a */
        /*0050*/                   IMAD.WIDE.U32 R4, R7, R10, c[0x0][0x168] ;              /* 0x00005a0007047625 */
        /* 0x000fd000078e000a */
        /*0060*/                   LDG.E.SYS R2, [R2] ;                                    /* 0x0000000002027381 */
        /*0070*/                   LDG.E.SYS R4, [R4] ;                                    /* 0x0000000004047381 */
        /* 0x000ee200001ee900 */
        /*0080*/                   LOP3.LUT R0, R2, 0x80808080, RZ, 0xfc, !PT ;            /* 0x8080808002007812 */
        /* 0x004fe400078efcff */
        /*0090*/                   LOP3.LUT R6, R4, 0x7f7f7f7f, RZ, 0xc0, !PT ;            /* 0x7f7f7f7f04067812 */
        /* 0x008fe400078ec0ff */
        /*00a0*/                   LOP3.LUT R8, R2, 0x80808080, R4, 0x84, !PT ;            /* 0x8080808002087812 */
        /* 0x000fc600078e8404 */
        /*00b0*/                   IMAD.IADD R9, R0, 0x1, -R6 ;                            /* 0x0000000100097824 */
        /* 0x000fe400078e0a06 */
        /*00c0*/                   IMAD.WIDE.U32 R6, R7, R10, c[0x0][0x170] ;              /* 0x00005c0007067625 */
        /* 0x000fc600078e000a */
        /*00d0*/                   LOP3.LUT R8, R9, R8, RZ, 0x3c, !PT ;                    /* 0x0000000809087212 */
        /* 0x000fd000078e3cff */
        /*00e0*/                   STG.E.SYS [R6], R8 ;                                    /* 0x0000000806007386 */
        /*00f0*/                   EXIT ;                                                  /* 0x000000000000794d */
        /*0100*/                   BRA 0x100;                                              /* 0xfffffff000007947 */
        /*0110*/                   NOP;                                                    /* 0x0000000000007918 */
        /*0120*/                   NOP;                                                    /* 0x0000000000007918 */
        /*0130*/                   NOP;                                                    /* 0x0000000000007918 */
        /*0140*/                   NOP;                                                    /* 0x0000000000007918 */
        /*0150*/                   NOP;                                                    /* 0x0000000000007918 */
        /*0160*/                   NOP;                                                    /* 0x0000000000007918 */
        /*0170*/                   NOP;                                                    /* 0x0000000000007918 */
Fatbin elf code:
arch = sm_72
producer = cuda
host = linux
	code for sm_72
	.headerflags    @"EF_CUDA_SM72 EF_CUDA_PTX_SM(EF_CUDA_SM72)"
Abs. code:
              C[threadIdx.x]=__vabs4(A[threadIdx.x],B[threadIdx.x]);
Abs. dump:
Fatbin elf code:
arch = sm_30
producer = cuda
host = linux
	code for sm_30
        /*0018*/                   MOV32I R5, 0x4;                               /* 0x1800000010015de2 */
        /*0028*/                   IMAD.U32.U32.HI.X R3, R0, R5, c[0x0][0x144];  /* 0x208a80051000dc43 */
        /*0030*/                   LD.E R2, [R2];                                /* 0x8400000000209c85 */
        /*0038*/                   ISCADD R4.CC, R0, c[0x0][0x150], 0x2;         /* 0x4001400540011c43 */
        /* 0x20000002f04283f7 */
        /*0048*/                   IMAD.U32.U32.HI.X R5, R0, R5, c[0x0][0x154];  /* 0x208a800550015c43 */
        /*0050*/                   VABSDIFF4.SD R0, R2, RZ, RZ;                  /* 0x8bfe844cfc201c64 */
        /*0058*/                   ST.E [R4], R0;                                /* 0x9400000000401c85 */
        /*0060*/                   EXIT;                                         /* 0x8000000000001de7 */
        /*0068*/                   BRA 0x68;                                     /* 0x4003ffffe0001de7 */
        /*0070*/                   NOP;                                          /* 0x4000000000001de4 */
        /*0078*/                   NOP;                                          /* 0x4000000000001de4 */
Fatbin elf code:
arch = sm_35
producer = cuda
host = linux
	code for sm_35
        /*0018*/                   MOV32I R5, 0x4;                               /* 0x74000000021fc016 */
        /*0028*/                   IMAD.U32.U32.HI.X R3, R0, R5, c[0x0][0x144];  /* 0x92101400289c000e */
        /*0030*/                   LD.E R2, [R2];                                /* 0xc4800000001c0808 */
        /*0038*/                   ISCADD R4.CC, R0, c[0x0][0x150], 0x2;         /* 0x60c408002a1c0012 */
        /* 0x08000000bc10a0fc */
        /*0048*/                   IMAD.U32.U32.HI.X R5, R0, R5, c[0x0][0x154];  /* 0x921014002a9c0016 */
        /*0050*/                   VABSDIFF4.SD R0, R2, RZ, RZ;                  /* 0x80dbffa27f9c0802 */
        /*0058*/                   ST.E [R4], R0;                                /* 0xe4800000001c1000 */
        /*0060*/                   EXIT;                                         /* 0x18000000001c003c */
        /*0068*/                   BRA 0x68;                                     /* 0x12007ffffc1c003c */
        /*0070*/                   NOP;                                          /* 0x85800000001c3c02 */
        /*0078*/                   NOP;                                          /* 0x85800000001c3c02 */
Fatbin elf code:
arch = sm_37
producer = cuda
host = linux
	code for sm_37
Fatbin elf code:
arch = sm_50
producer = cuda
host = linux
	code for sm_50
        /*0018*/                   SHL R4, R0.reuse, 0x2 ;                /* 0x3848000000270004 */
        /* 0x001fc840fec007f5 */
        /*0028*/                   SHR.U32 R5, R0, 0x1e ;                 /* 0x3828000001e70005 */
        /*0030*/                   IADD R2.CC, R4.reuse, c[0x0][0x140] ;  /* 0x4c10800005070402 */
        /*0038*/                   IADD.X R3, R5, c[0x0][0x144] ;         /* 0x4c10080005170503 */
        /*0048*/                   LDG.E R2, [R2] ;                       /* 0xeed4200000070202 */
        /*0050*/                   IADD R4.CC, R4, c[0x0][0x150] ;        /* 0x4c10800005470404 */
        /*0058*/                   IADD.X R5, R5, c[0x0][0x154] ;         /* 0x4c10080005570505 */
        /* 0x001fd800fe2307f6 */
        /*0068*/                   PRMT R0, R2.reuse, 0xba98, RZ ;        /* 0x36c07f8ba9870200 */
        /*0070*/                   LOP.XOR R6, R2, R0 ;                   /* 0x5c47040000070206 */
        /*0078*/                   LOP32I.AND R0, R0, 0x1010101 ;         /* 0x0400101010170000 */
        /* 0x001ffc00fe2007f2 */
        /*0088*/                   IADD R6, R6, R0 ;                      /* 0x5c10000000070606 */
        /*0090*/                   STG.E [R4], R6 ;                       /* 0xeedc200000070406 */
Fatbin elf code:
arch = sm_52
producer = cuda
host = linux
	code for sm_52
Fatbin elf code:
arch = sm_60
producer = cuda
host = linux
	code for sm_60
        /*0030*/                   IADD R2.CC, R4, c[0x0][0x140] ;  /* 0x4c10800005070402 */
        /* 0x001f9800fc2107e6 */
        /*0068*/                   PRMT R0, R2, 0xba98, RZ ;        /* 0x36c07f8ba9870200 */
        /* 0x001ffc00fe2007e2 */
Fatbin elf code:
arch = sm_61
producer = cuda
host = linux
	code for sm_61
Fatbin elf code:
arch = sm_70
producer = cuda
host = linux
	code for sm_70
        /*0020*/                   S2R R4, SR_TID.X ;                           /* 0x0000000000047919 */
        /*0030*/                   MOV R5, 0x4 ;                                /* 0x0000000400057802 */
        /*0040*/                   IMAD.WIDE.U32 R2, R4, R5, c[0x0][0x160] ;    /* 0x0000580004027625 */
        /* 0x001fd400078e0005 */
        /*0050*/                   LDG.E.SYS R2, [R2] ;                         /* 0x0000000002027381 */
        /* 0x000ea200001ee900 */
        /*0060*/                   IMAD.WIDE.U32 R4, R4, R5, c[0x0][0x170] ;    /* 0x00005c0004047625 */
        /* 0x000fe200078e0005 */
        /*0070*/                   PRMT R0, R2, 0xba98, RZ ;                    /* 0x0000ba9802007816 */
        /* 0x004fc800000000ff */
        /*0080*/                   LOP3.LUT R6, R2, R0, RZ, 0x3c, !PT ;         /* 0x0000000002067212 */
        /* 0x000fe400078e3cff */
        /*0090*/                   LOP3.LUT R0, R0, 0x1010101, RZ, 0xc0, !PT ;  /* 0x0101010100007812 */
        /* 0x000fca00078ec0ff */
        /*00a0*/                   IMAD.IADD R6, R6, 0x1, R0 ;                  /* 0x0000000106067824 */
        /* 0x000fd000078e0200 */
        /*00b0*/                   STG.E.SYS [R4], R6 ;                         /* 0x0000000604007386 */
        /*00c0*/                   EXIT ;                                       /* 0x000000000000794d */
        /*00d0*/                   BRA 0xd0;                                    /* 0xfffffff000007947 */
        /*00e0*/                   NOP;                                         /* 0x0000000000007918 */
        /*00f0*/                   NOP;                                         /* 0x0000000000007918 */
Fatbin elf code:
arch = sm_72
producer = cuda
host = linux
	code for sm_72
Add. code:
              C[threadIdx.x]=__vadd4(A[threadIdx.x],B[threadIdx.x]);
Add. dump:
arch = sm_30
producer = cuda
host = linux
	code for sm_30
        /*0068*/                   VADD4.UD.U8.U8 R0, R2, R4, RZ;                /* 0x81fe844c10201c04 */
Fatbin elf code:
arch = sm_35
producer = cuda
host = linux
	code for sm_35
        /*0068*/                   VADD4.UD.U8.U8 R0, R2, R4, RZ;                /* 0xd0c3fda2021c0801 */
Fatbin elf code:
arch = sm_37
producer = cuda
host = linux
	code for sm_37
Fatbin elf code:
arch = sm_50
producer = cuda
host = linux
	code for sm_50
        /* 0x001f9440fe2107f1 */
        /*0088*/                   LOP32I.AND R0, R2, 0x7f7f7f7f ;           /* 0x0407f7f7f7f70200 */
        /*0090*/                   LOP32I.AND R9, R4.reuse, 0x7f7f7f7f ;     /* 0x0407f7f7f7f70409 */
        /*0098*/                   LOP3.LUT R8, R4, c[0x2][0x0], R2, 0x48 ;  /* 0x0248010800070408 */
        /*00a8*/                   IADD R9, R0, R9 ;                         /* 0x5c10000000970009 */
Fatbin elf code:
arch = sm_52
producer = cuda
host = linux
	code for sm_52
Fatbin elf code:
arch = sm_60
producer = cuda
host = linux
	code for sm_60
Fatbin elf code:
arch = sm_61
producer = cuda
host = linux
	code for sm_61
Fatbin elf code:
arch = sm_70
producer = cuda
host = linux
	code for sm_70
        /*0080*/                   LOP3.LUT R0, R2, 0x7f7f7f7f, RZ, 0xc0, !PT ;            /* 0x7f7f7f7f02007812 */
        /* 0x004fe400078ec0ff */
        /*0090*/                   LOP3.LUT R6, R4.reuse, 0x7f7f7f7f, RZ, 0xc0, !PT ;      /* 0x7f7f7f7f04067812 */
        /* 0x048fe400078ec0ff */
        /*00a0*/                   LOP3.LUT R8, R4, 0x80808080, R2, 0x48, !PT ;            /* 0x8080808004087812 */
        /* 0x000fc600078e4802 */
        /*00b0*/                   IMAD.IADD R9, R0, 0x1, R6 ;                             /* 0x0000000100097824 */
        /* 0x000fe400078e0206 */
Fatbin elf code:
arch = sm_72
producer = cuda
host = linux
	code for sm_72
From the dump information provided above,it’s seem that you are gradually removing SIMD hardware resources since Maxwell arch.
Can I confirm that or it’s problem of improper use of the nvcc compiler.
We want to reproduce this issue first.
Would you mind to share a complete sample with us so we can pass it to our internal team for comment directly.
A practice sample
Code:
#include <cuda_runtime.h>
#include <stdio.h>
        //C[threadIdx.x]=__vabs4(A[threadIdx.x]);
        //C[threadIdx.x]=__vadd4(A[threadIdx.x],B[threadIdx.x]);
        //C[threadIdx.x]=__vadd4(__vabs4(__vsub4(A[threadIdx.x],B[threadIdx.x])),0);
        //C[threadIdx.x]=__vsadu4(A[threadIdx.x],B[threadIdx.x]);
int main()
        printf("1.select one of the instruction row in the kernel function above to test the accordingly simd instruction \n");
        printf("2.generate fatbin using nvcc options -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_72,code=sm_72\n");
        printf("3.dump the app[cuobjdump -saas app] compiled in step2 and you will get the specified GPU archs compound assembly codes \n");
Compile:
nvcc -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_72,code=sm_72 vsadcuda.cu -o app
Dump:
cuobjdump -saas app
Finally , you can check the difference among the compound assembly codes that include specified GPU archs.
Thanks for the sample.
We will share more information with you once we got feedback from the developer team.
Is there any update on this?
Sorry that we are still checking this issue.
Will update more information with you once we got feedback from the CUDA team.
Could you help to provide the runnable that showing perf numbers for us to compare?
