Jetson Orin
• DeepStream Version
6.2
5.0.2
• TensorRT Version
8.4.1-1+cuda11.4
What is the expected performance of the Deesptream python sample apps test3 in ORIN? I am using a jetson Orin and the tests run at 30 FPS.
The deepstream version should be DeepStream 6.1.1, can you confirm?
Same question for this topic: How to use custom yolov4-tiny in deepstream6 with rtsp output?
yes, I meant to type DeepStream 6.1.1.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one.
DeepStream is just a SDK but not an application. To measure performance with DeppStream, please refer to Performance — DeepStream 6.1.1 Release documentation (nvidia.com)
