Pgf90: command not found
Dear all,
I have installed the PGI following the steps below:
$ wget https://developer.download.nvidia.com/hpc-sdk/21.11/nvhpc-21-11_21.11_amd64.deb \
       https://developer.download.nvidia.com/hpc-sdk/21.11/nvhpc-2021_21.11_amd64.deb
$ apt-get install ./nvhpc-21-11_21.11_amd64.deb ./nvhpc-2021_21.11_amd64.deb
It finished and produced the PGI in /opt/nvidia/hpc_sdk/.
Then I set path as follow:
$NVARCH=`uname -s`_`uname -m` && export NVARCH
$ NVCOMPILERS=/opt/nvidia/hpc_sdk/Linux_x86_64 && export NVCOMPILERS
$ MANPATH=$MANPATH:$NVCOMPILERS/$NVARCH/21.11/compilers/man && export MANPATH
$ PATH=$NVCOMPILERS/$NVARCH/21.11/compilers/bin:$PATH && export PATH
However the pgf90 still not work when I try with “pgf90 -V” or other pgf90 command, it said “pgf90: command not found”
My OS is Ubuntu 20.04.3
I’m not sure what’s wrong with my steps. Could you please help to guide me how to install PGI successfully.
Chi
Hi Chi,
In you’re setting of “NVCOMPILERS” you include ‘Linux_x86_64’ which is the same as the setting for NVARCH. Hence the PATH will end up having a ‘Linux_x86_64’ added twice. Removing the ‘Linux_x86_64’ from NVCOMPILER should fix the issue.
From: https://docs.nvidia.com/hpc-sdk/hpc-sdk-install-guide/index.html#install-linux-end-usr-env-settings
$ NVARCH=`uname -s`_`uname -m`; export NVARCH
$ NVCOMPILERS=/opt/nvidia/hpc_sdk; export NVCOMPILERS
$ MANPATH=$MANPATH:$NVCOMPILERS/$NVARCH/21.11/compilers/man; export MANPATH
$ PATH=$NVCOMPILERS/$NVARCH/21.11/compilers/bin:$PATH; export PATH
Hope this helps,
Mat
