I have been trying to install PGI 18.4 Community edition on Ubuntu 18.04, I have been following the step by step guide. But I can’t make the compilers accessible, I have tried the following process
% setenv PGI /opt/pgi
% set path=(/opt/pgi/linux86-64/18.4/bin $path)
% setenv MANPATH "$MANPATH":/opt/pgi/linux86-64/18.4/man
% setenv LM_LICENSE_FILE /opt/pgi/license.dat:"$LM_LICENSE_FILE"
But I always get the error MANPATH variable not found
LM_LICENSE_FILE variable not found
and also this one,
$ export PGI=/opt/pgi;
$ export PATH=/opt/pgi/linux86-64/18.4/bin:$PATH;
$ export MANPATH=$MANPATH:/opt/pgi/linux86-64/18.4/man;
$ export LM_LICENSE_FILE=$LM_LICENSE_FILE:/opt/pgi/license.dat;
The latter does not give me any error, but I can’t see the compilers after typing some of the followings.
For Fortran 77, use: pgf77 -V x.f
For Fortran 2003, use: pgfortran -V x.f
For C++, use: pgc++ -V x.cpp
For ANSI C, use: pgcc -V x.c
And then it comes,
Command ‘pgcc’ not found, did you mean:
command ‘gcc’ from deb gcc
command ‘cgcc’ from deb sparseTry: apt install
And so forth, for each one of the compilers.
I would like to know how to make it work, what am I doing wrong? Please
Thank you guys
