I’m having problems compiling PhysX 3.2 in debug mode using the recommended CHECKED versions of the library. I’m using vs2010 Express.
Here’s the error message
PhysX3ExtensionsCHECKED.lib(ExtDefaultErrorCallback.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in iphysicsTest.obj
I googled for a solution and discovered you can set the _ITERATOR_DEBUG_LEVEL using the Preprocessor
[url]visual studio 2010 - How to set _ITERATOR_DEBUG_LEVEL in VS2010? - Stack Overflow but if I set it to 0 that just generates a bunch more mismatch errors.
Anybody know how to get around this problem?
Bird
