Physx: PBD - ParticleSystem/Points reset on Stop
edit: Create 2022.1.5
Please see the attached video, where I create an RB and a ParticleSystem/Points from a Cone on the same Layer.
Notice that when the Simulation is stopped, the RB is reset, but the ParticleSystem/Points was not.
Is there some additional step that needs taken to have the ParticleSytem/Points reset on Stop?
edit: I’ve attached a scene where you can hit Play and Stop to repro the results shown in the video.
ParticleSample_Points_Reset.usd (46.4 KB)
by any chance do you have omni.physx.flatcache extension enabled? I tried to repro in our upcoming release and things seems to work fine. Though there is a known issue that with the flatcache extension the particles wont reset.
Yes the repro resets correctly for me on 2022.1.5 - but with Flatache enabled I can repro what you see.
Flatcache! Ugh! Thanks for checking on this guys…sorry for the noise.
Create 2202.1.5, Soo…the plot thickens, it seems that I cannot prevent Flatcache from loading and enabling itself when I start Create.
I was wondering why I’d gotten in this situation with Particles - and so I went and tried to prevent Flatcache from loading and enabling itself - and I cannot.
Some extension that you have enabled by default does have a dependency on omni.physx.flatcache, by any chance do you have omni.physx.forcefields extension enabled? That one requires omni.physx.flatcache and would enable it from start.
