I have a few questions regarding the excel sheet that generates the pinumx .dts files:
- Why there are hidden rows representing pins? (for example rows 10-12 in the HDMI_A01 sheet)
- What is the meaning of the following terms:
- drive 1
- initiator target mode
- LPDR enable
- If I have an unused pin, should I put it on unused or not assigned? what is the difference between both cases?
- If I don’t use specific pin. it means it will be on high z?
