Hi All,
On a custom board we are trying to setup the GPIO’s so they reflect the design.
I have a ton of pins that are not used on the TX1 400pin header.
Question 1:
Is it okay that I simply set them all to “Unused xxx” and pin direction to “Not Assigned”
Question 2:
I did get some errors due the 3.3V tolerance being enabled for PCE-E pins but I unprotected the excel sheet and set them as “Disable” - I assume this is okay?
Lasse
