Hi All,
I am planning to install another WiFi interface for my Jetson TX2.
However, after I am searching to the internet,
it is not straightforward to install a new driver in Jetson TX2.
I am asking whether there is any suggestion for WiFi Card that can be plug-in-play to the Jetson TX2 so that I don’t need to install any driver.
I am considering to use the M.2 Key Type E slot to install this card.
Thank you for the response in advance.
Best,
Hi dark_cly,
We are not support M.2 WiFi on TX2.
Sorry for inconvenience.
Hi Carolyuu,
Thank you for your reply.
How about USB or PCIe slot?
Is there any plug-and-play WiFi device that I can use through USB or PCIe slot?
My goal is to enable dual WiFi interfaces on my jetson TX2 without bothering to install an additional driver.
I wonder if I can add the WiFi card similar to the built-in WiFi card on jetson TX2.
Thank you,
Regards
Hi dark_cly,
Why don’t you use onboard Wi-Fi?
We have not test WiFi device through USB or PCIe.
Hi Carolyuu,
As I mentioned before that I needed to enable dual WiFi interfaces for my jetson TX2.
My ultimate goal is to provide a more reliable WiFi connection for the mobile device without connection loss. Note that with a single WiFi interface connection loss occurs during WiFi Handover.
So that I wonder if there is a plug-and-play WiFi adapter for the jetson TX2.
Thank you,
Regards
