I recently upgraded from a 1070Ti to a 2080Ti, and with the new graphics card came nearly unusable performance on my primary portrait 4k display. When I first start X it is fine, but within 10 seconds it will drop to 30 fps, as confirmed by testufo.com, and with several frames of latency. If I screen record my desktop and play it back on another display it is at the correct refresh rate. This only happens if the monitor is
- at its native 4K resolution. Reducing it to a non-native 1080p fixes it
- Rotated in any way. Setting it to
No rotation
also fixes it - Using DisplayPort. Using HDMI makes the monitor limited to 30Hz, but fixes the latency
- Using X11. Using wayland makes it perform correctly, but wayland is still unusable in other ways so that is not a real option.
I have tried without success:
- Forcing G-SYNC on and off
- Various different display port cables
- Both “60Hz” display modes – Sometimes
nvidia-settings
will show a second 60Hz display mode that is actually 59.97 - Running my other high-refresh rate display at 60Hz instead of it’s native 165
- Every combination of Force (Full|) Composition Pipeline settings
- Only attaching the affected 4k display
- Changing the XVideo sync display
- Using other DisplayPort outputs on my GPU
- Using OpenBox
Arch Linux / 6.1.12-arch1-1/ 525.89.02
nvidia-bug-report.log.gz (549.1 KB)
