Possible issue with P2 port on BlueField-2 DPU
I have a BlueField-2 DPU where port p2 still appears active in the operating system as
p2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000.
I have already configured NUM_OF_PF=2 and performed a full configuration reset using mlxconfig -d /dev/mst/mt41686_pciconf0 reset. I verified with ip linkand mlxconfig query that the configuration was applied correctly, but port p2 still appears active even though it should not be enabled or used in my current setup. I would like to know if this could be a firmware or driver issue, or if there is something wrong with my configuration causing port p2 to remain active.
Only I want use P0 and P1, using DOCA 3.1 with latest firmware
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
   valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: oob_net0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 08:c0:eb:b2:43:96 brd ff:ff:ff:ff:ff:ff
altname enamlnxbf17i0
inet 172.28.20.207/24 brd 172.28.20.255 scope global dynamic noprefixroute oob_net0
   valid_lft 3535sec preferred_lft 3535sec
inet6 fe80::ac0:ebff:feb2:4396/64 scope link
3: tmfifo_net0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:1a:ca:ff:ff:01 brd ff:ff:ff:ff:ff:ff
inet 192.168.100.2/30 brd 192.168.100.3 scope global noprefixroute tmfifo_net0
inet6 fe80::21a:caff:feff:ff01/64 scope link
4: p0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1550 qdisc mq state DOWN group default qlen 1000
link/ether 08:c0:eb:b2:43:8e brd ff:ff:ff:ff:ff:ff
altname enp3s0f0np0
inet6 fe80::ac0:ebff:feb2:438e/64 scope link
5: p1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1550 qdisc mq state UP group default qlen 1000
link/ether 08:c0:eb:b2:43:8f brd ff:ff:ff:ff:ff:ff
altname enp3s0f1np1
inet6 fe80::ac0:ebff:feb2:438f/64 scope link
6: p2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether ec:0d:9a:63:30:6b brd ff:ff:ff:ff:ff:ff
altname enp3s0f2np2
inet6 fe80::ee0d:9aff:fe63:306b/64 scope link
7: pf0hpf: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 128
link/ether 8a:cf:e2:e4:1b:a9 brd ff:ff:ff:ff:ff:ff
altname enp3s0f0nc1pf0
inet6 fe80::88cf:e2ff:fee4:1ba9/64 scope link
11: pf1hpf: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 128
link/ether 62:f3:24:df:d7:56 brd ff:ff:ff:ff:ff:ff
altname enp3s0f1nc1pf1
inet6 fe80::60f3:24ff:fedf:d756/64 scope link
15: ovs-doca: <BROADCAST,MULTICAST,PROMISC> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether ca:5c:50:7f:f6:cf brd ff:ff:ff:ff:ff:ff
16: br0-ovs: <BROADCAST,MULTICAST,PROMISC> mtu 1500 qdisc noop state DOWN group default qlen 1000
17: br1-ovs: <BROADCAST,MULTICAST,PROMISC> mtu 1500 qdisc noop state DOWN group default qlen 1000
Device type: BlueField2
Description: BlueField-2 P-Series DPU 25GbE Dual-Port SFP56; PCIe Gen4 x8; Crypto and Secure Boot Enabled; 16GB on-board DDR; 1GbE OOB management; HHHL
Device: /dev/mst/mt41686_pciconf0
Configurations: Next Boot
    ACCURATE_TX_SCHEDULER                       False(0)
    ADVANCED_PCI_SETTINGS                       False(0)
    AES_XTS_TWEAK_INC_64                        False(0)
    ALLOW_RD_COUNTERS                           True(1)
    ATS_ENABLED                                 False(0)
    AUTO_POWER_SAVE_LINK_DOWN_P1                False(0)
    AUTO_POWER_SAVE_LINK_DOWN_P2                False(0)
    BOOT_DBG_LOG                                False(0)
    BOOT_INTERRUPT_DIS                          False(0)
    BOOT_LACP_DIS                               True(1)
    BOOT_PKEY                                   0
    BOOT_UNDI_NETWORK_WAIT                      0
    BOOT_VLAN_EN                                False(0)
    BOOT_VLAN                                   1
    CLAMP_TGT_RATE_AFTER_TIME_INC_P1            True(1)
    CLAMP_TGT_RATE_AFTER_TIME_INC_P2            True(1)
    CLAMP_TGT_RATE_P1                           False(0)
    CLAMP_TGT_RATE_P2                           False(0)
    CNP_802P_PRIO_P1                            6
    CNP_802P_PRIO_P2                            6
    CNP_DSCP_P1                                 48
    CNP_DSCP_P2                                 48
    CQE_COMPRESSION                             BALANCED(0)
    CRYPTO_POLICY                               UNRESTRICTED(1)
    DCBX_CEE_P1                                 False(0)
    DCBX_CEE_P2                                 False(0)
    DCBX_IEEE_P1                                False(0)
    DCBX_IEEE_P2                                False(0)
    DCBX_WILLING_P1                             False(0)
    DCBX_WILLING_P2                             False(0)
    DCE_TCP_G_P1                                1019
    DCE_TCP_G_P2                                1019
    DCE_TCP_RTT_P1                              1
    DCE_TCP_RTT_P2                              1
    DCR_LIFO_SIZE                               16384
    DO_NOT_CLEAR_PORT_STATS_P1                  False(0)
    DO_NOT_CLEAR_PORT_STATS_P2                  False(0)
    DPU_RESET_NOTIFICATION_ENABLED              DISABLED(0)
    DUP_MAC_ACTION_P1                           LAST_CFG(0)
    DUP_MAC_ACTION_P2                           LAST_CFG(0)
    DYNAMIC_VF_MSIX_TABLE                       False(0)
    ECPF_ESWITCH_MANAGER                        ECPF(1)
    ECPF_PAGE_SUPPLIER                          ECPF(1)
    ESWITCH_HAIRPIN_DESCRIPTORS                 Array\[0..7\]
    ESWITCH_HAIRPIN_TOT_BUFFER_SIZE             Array\[0..7\]
    ETH_ETS_GRANULARITY_P1                      DEVICE_DEFAULT(0)
    ETH_ETS_GRANULARITY_P2                      DEVICE_DEFAULT(0)
    ETS_SCHED_MODE_P1                           device_default(0)
    ETS_SCHED_MODE_P2                           device_default(0)
    EXP_ROM_NVME_UEFI_x86_ENABLE                True(1)
    EXP_ROM_PXE_ENABLE                          True(1)
    EXP_ROM_UEFI_ARM_ENABLE                     True(1)
    EXP_ROM_UEFI_x86_ENABLE                     True(1)
    EXP_ROM_VIRTIO_BLK_UEFI_ARM_ENABLE          False(0)
    EXP_ROM_VIRTIO_BLK_UEFI_x86_ENABLE          False(0)
    EXP_ROM_VIRTIO_NET_PXE_ENABLE               False(0)
    EXP_ROM_VIRTIO_NET_UEFI_ARM_ENABLE          False(0)
    EXP_ROM_VIRTIO_NET_UEFI_x86_ENABLE          False(0)
    FLEX_IPV4_OVER_VXLAN_PORT                   0
    FLEX_PARSER_PROFILE_ENABLE                  0
    HAIRPIN_DATA_BUFFER_LOCK                    False(0)
    HIDE_PORT2_PF                               False(0)
    HOST_CHAINING_CACHE_DISABLE                 False(0)
    HOST_CHAINING_DESCRIPTORS                   Array\[0..7\]
    HOST_CHAINING_MODE                          DISABLED(0)
    HOST_CHAINING_TOTAL_BUFFER_SIZE             Array\[0..7\]
    HOST_PRIV_FLASH_ACCESS                      DEVICE_DEFAULT(0)
    HOST_PRIV_FW_UPDATE                         DEVICE_DEFAULT(0)
    HOST_PRIV_NIC_RESET                         DEVICE_DEFAULT(0)
    HOST_PRIV_NV_GLOBAL                         DEVICE_DEFAULT(0)
    HOST_PRIV_NV_HOST                           DEVICE_DEFAULT(0)
    HOST_PRIV_NV_INTERNAL_CPU                   DEVICE_DEFAULT(0)
    HOST_PRIV_NV_PORT                           DEVICE_DEFAULT(0)
    HOST_PRIV_PCC_UPDATE                        DEVICE_DEFAULT(0)
    IB_ETS_GRANULARITY_P1                       DEVICE_DEFAULT(0)
    IB_ETS_GRANULARITY_P2                       DEVICE_DEFAULT(0)
    IB_ROUTING_MODE_P1                          LID(1)
    IB_ROUTING_MODE_P2                          LID(1)
    ICM_CACHE_MODE                              DEVICE_DEFAULT(0)
    INITIAL_ALPHA_VALUE_P1                      1023
    INITIAL_ALPHA_VALUE_P2                      1023
    INTERNAL_CPU_ESWITCH_MANAGER                ECPF(0)
    INTERNAL_CPU_IB_VPORT0                      ECPF(0)
    INTERNAL_CPU_MODEL                          EMBEDDED_CPU(1)
    INTERNAL_CPU_OFFLOAD_ENGINE                 ENABLED(0)
    INTERNAL_CPU_PAGE_SUPPLIER                  ECPF(0)
    INTERNAL_CPU_RSHIM                          ENABLED(0)
    INT_LOG_MAX_PAYLOAD_SIZE                    AUTOMATIC(0)
    IP_OVER_VXLAN_EN                            False(0)
    IP_VER                                      IPv6(1)
    KEEP_ETH_LINK_UP_P1                         True(1)
    KEEP_ETH_LINK_UP_P2                         True(1)
    KEEP_IB_LINK_UP_P1                          False(0)
    KEEP_IB_LINK_UP_P2                          False(0)
    KEEP_LINK_UP_ON_BOOT_P1                     True(1)
    KEEP_LINK_UP_ON_BOOT_P2                     True(1)
    KEEP_LINK_UP_ON_STANDBY_P1                  False(0)
    KEEP_LINK_UP_ON_STANDBY_P2                  False(0)
    LAG_RESOURCE_ALLOCATION                     PRE_ALLOCATION(1)
    LARGE_MTU_TWEAK_64                          False(0)
    LEGACY_BOOT_PROTOCOL                        NONE(0)
    LLDP_NB_DCBX_P1                             True(1)
    LLDP_NB_DCBX_P2                             True(1)
    LLDP_NB_RX_MODE_P1                          ALL(2)
    LLDP_NB_RX_MODE_P2                          ALL(2)
    LLDP_NB_TX_MODE_P1                          ALL(2)
    LLDP_NB_TX_MODE_P2                          ALL(2)
    LOG_DCR_HASH_TABLE_SIZE                     11
LOG_MAX_OUTSTANDING_READ_ATOMIC 0
    LOG_MAX_OUTSTANDING_WQE                     7
    LOG_MAX_QUEUE                               17
    LOG_TX_PSN_WINDOW                           7
    LRO_LOG_TIMEOUT0                            6
    LRO_LOG_TIMEOUT1                            7
    LRO_LOG_TIMEOUT2                            8
    LRO_LOG_TIMEOUT3                            13
    MANAGEMENT_PF_MODE                          MNG_PF_ENABLE(1)
    MAX_PACKET_LIFETIME                         0
    MCTP_I3C_DISABLE                            False(0)
    MEMIC_BAR_SIZE                              0
    MEMIC_SIZE_LIMIT                            \_256KB(1)
    MIN_TIME_BETWEEN_CNPS_P1                    4
    MIN_TIME_BETWEEN_CNPS_P2                    4
    MKEY_BY_NAME                                False(0)
    MKEY_BY_NAME_RANGE                          DEVICE_DEFAULT(0)
    MPFS_MC_LOOPBACK_DISABLE_P1                 False(0)
    MPFS_MC_LOOPBACK_DISABLE_P2                 False(0)
    MPFS_UC_LOOPBACK_DISABLE_P1                 False(0)
    MPFS_UC_LOOPBACK_DISABLE_P2                 False(0)
    MULTIPATH_DSCP                              DEVICE_DEFAULT(0)
    MULTI_PCI_RESOURCE_SHARING                  DEVICE_DEFAULT(0)
    MULTI_PORT_VHCA_EN                          False(0)
    NON_PREFETCHABLE_PF_BAR                     False(0)
    NUM_OF_PFC_P1                               8
    NUM_OF_PFC_P2                               8
    NUM_OF_PF                                   2
    NUM_OF_TC_P1                                \_8_TCs(0)
    NUM_OF_TC_P2                                \_8_TCs(0)
    NUM_OF_VFS                                  8
    NUM_OF_VL_P1                                \_4_VLs(3)
    NUM_OF_VL_P2                                \_4_VLs(3)
    NUM_PF_MSIX                                 127
    NUM_PF_MSIX_VALID                           True(1)
    NUM_VF_MSIX                                 11
    NVME_EMULATION_CLASS_CODE                   67586
    NVME_EMULATION_DEVICE_ID                    24577
    NVME_EMULATION_ENABLE                       False(0)
    NVME_EMULATION_MAX_QUEUE_DEPTH              0
    NVME_EMULATION_NUM_MSIX                     0
    NVME_EMULATION_NUM_PF                       1
    NVME_EMULATION_NUM_VF                       0
    NVME_EMULATION_REVISION_ID                  0
    NVME_EMULATION_SUBSYSTEM_ID                 0
    NVME_EMULATION_SUBSYSTEM_VENDOR_ID          0
    NVME_EMULATION_VENDOR_ID                    5555
    P2P_ORDERING_MODE                           DEVICE_DEFAULT(0)
    PARTIAL_RESET_EN                            False(0)
    PCC_INT_EN                                  False(0)
    PCC_INT_NP_RTT_DATA_MODE                    RTT_V0(64)
    PCC_INT_NP_RTT_DSCP_EN                      True(1)
    PCC_INT_NP_RTT_DSCP                         26
    PCC_INT_SYSTEM_RTT                          0
    PCIE_CREDIT_TOKEN_TIMEOUT                   0
    PCIE_IN_BAND_VDM_DISABLE                    False(0)
    PCIE_SMBUS_DISABLE                          False(0)
    PCI_ATOMIC_MODE                             PCI_ATOMIC_DISABLED_EXT_ATOMIC_ENABLED(0)
    PCI_DOWNSTREAM_PORT_OWNER                   Array\[0..15\]
    PCI_SWITCH_EMULATION_ENABLE                 False(0)
    PCI_SWITCH_EMULATION_NUM_PORT               0
    PCI_WR_ORDERING                             per_mkey(0)
    PER_PF_NUM_SF                               True(1)
    PF_BAR2_ENABLE                              False(0)
    PF_BAR2_SIZE                                0
    PF_DEVICE_ID_ENABLE                         True(1)
    PF_DEVICE_ID                                41686
    PF_LOG_BAR_SIZE                             5
    PF_NUM_OF_VF                                0
    PF_NUM_OF_VF_VALID                          True(1)
    PF_NUM_PF_MSIX                              63
    PF_NUM_PF_MSIX_VALID                        False(0)
    PF_SD_GROUP                                 0
    PF_SF_BAR_SIZE                              10
    PF_TOTAL_SF                                 8
    PHY_AUTO_NEG_P1                             DEVICE_DEFAULT(0)
    PHY_AUTO_NEG_P2                             DEVICE_DEFAULT(0)
    PHY_COUNT_LINK_UP_DELAY                     DELAY_NONE(0)
    PHY_FEC_OVERRIDE_P1                         DEVICE_DEFAULT(0)
    PHY_FEC_OVERRIDE_P2                         DEVICE_DEFAULT(0)
    PHY_RATE_MASK_OVERRIDE_P1                   False(0)
    PHY_RATE_MASK_OVERRIDE_P2                   False(0)
    PLDM_FW_UPDATE_DISABLE                      False(0)
    PORT_OWNER                                  True(1)
    PRIO_TAG_REQUIRED_EN                        False(0)
    PROG_PARSE_GRAPH                            False(0)
    QOS_TRUST_STATE_P1                          TRUST_PCP(1)
    QOS_TRUST_STATE_P2                          TRUST_PCP(1)
    RATE_REDUCE_MONITOR_PERIOD_P1               4
    RATE_REDUCE_MONITOR_PERIOD_P2               4
    RATE_TO_SET_ON_FIRST_CNP_P1                 0
    RATE_TO_SET_ON_FIRST_CNP_P2                 0
    RBT_DISABLE                                 False(0)
    RDE_DISABLE                                 False(0)
    RDMA_SELECTIVE_REPEAT_EN                    False(0)
    REAL_TIME_CLOCK_ENABLE                      False(0)
    RENEG_ON_CHANGE                             True(1)
    RESET_WITH_HOST_ON_ERRORS                   False(0)
    ROCE_ADAPTIVE_ROUTING_EN                    False(0)
    ROCE_CC_CNP_MODERATION_P1                   DEVICE_DEFAULT(0)
    ROCE_CC_CNP_MODERATION_P2                   DEVICE_DEFAULT(0)
    ROCE_CC_DCQCN_COMPATIBILITY_MODE            DEVICE_DEFAULT(0)
    ROCE_CC_LEGACY_DCQCN                        False(0)
    ROCE_CC_PRIO_MASK_P1                        255
    ROCE_CC_PRIO_MASK_P2                        255
    ROCE_CONTROL                                ROCE_ENABLE(2)
    ROCE_NEXT_PROTOCOL                          254
    ROCE_RTT_RESP_DSCP_MODE_P1                  DEVICE_DEFAULT(0)
    ROCE_RTT_RESP_DSCP_MODE_P2                  DEVICE_DEFAULT(0)
    ROCE_RTT_RESP_DSCP_P1                       0
    ROCE_RTT_RESP_DSCP_P2                       0
    RPG_AI_RATE_P1                              5
    RPG_AI_RATE_P2                              5
    RPG_BYTE_RESET_P1                           32767
    RPG_BYTE_RESET_P2                           32767
    RPG_GD_P1                                   11
    RPG_GD_P2                                   11
    RPG_HAI_RATE_P1                             50
    RPG_HAI_RATE_P2                             50
    RPG_MAX_RATE_P1                             0
    RPG_MAX_RATE_P2                             0
    RPG_MIN_DEC_FAC_P1                          50
    RPG_MIN_DEC_FAC_P2                          50
    RPG_MIN_RATE_P1                             1
    RPG_MIN_RATE_P2                             1
    RPG_THRESHOLD_P1                            1
    RPG_THRESHOLD_P2                            1
    RPG_TIME_RESET_P1                           300
    RPG_TIME_RESET_P2                           300
    RT_PPS_ENABLED_ON_POWERUP                   False(0)
    SAFE_MODE_ENABLE                            False(0)
    SILENT_MODE                                 False(0)
    SM_DISABLE                                  False(0)
    SRIOV_EN                                    False(0)
    SRIOV_IB_ROUTING_MODE_P1                    LID(1)
    SRIOV_IB_ROUTING_MODE_P2                    LID(1)
    STEERING_CACHE_REFRESH                      0
    STRICT_VF_MSIX_NUM                          False(0)
    SWITCH_COMPT_FEATURE_MASK                   0x0(0)
    TLS_OPTIMIZE                                False(0)
    TRACER_ENABLE                               True(1)
    TUNNEL_ECN_COPY_DISABLE                     False(0)
    TUNNEL_IP_PROTO_ENTROPY_DISABLE             False(0)
    TX_PCI_DATA_FETCH_LATENCY                   40
    TX_SCHEDULER_BURST                          0
    TX_SCHEDULER_FWS_REACTIVITY                 DIRECT(1)
    TX_SCHEDULER_LOCALITY_FACTOR                0
    TX_SCHEDULER_LOCALITY_MODE                  DEVICE_DEFAULT(0)
    UCTX_EN                                     True(1)
    UEFI_HII_EN                                 True(1)
    UEFI_LOGS                                   DISABLED(0)
    UNKNOWN_UPLINK_MAC_FLOOD_P1                 False(0)
    UNKNOWN_UPLINK_MAC_FLOOD_P2                 False(0)
    UPT_EMULATION_ENABLE                        True(1)
    USER_PROGRAMMABLE_CC                        False(0)
    VF_LOG_BAR_SIZE                             1
    VF_MIGRATION_MODE                           DEVICE_DEFAULT(0)
    VF_NODNIC_ENABLE                            False(0)
    VF_VPD_ENABLE                               False(0)
    VIRTIO_BLK_EMULATION_ENABLE                 False(0)
    VIRTIO_BLK_EMULATION_NUM_MSIX               2
    VIRTIO_BLK_EMULATION_NUM_PF                 0
    VIRTIO_BLK_EMULATION_NUM_VF                 0
    VIRTIO_BLK_EMULATION_PF_PCI_LAYOUT          VIRTIO_1_X(0)
    VIRTIO_BLK_EMULATION_SUBSYSTEM_ID           4162
    VIRTIO_BLK_EMULATION_VF_PCI_LAYOUT          VIRTIO_1_X(0)
    VIRTIO_BLK_EMU_SUBS_VENDOR_ID               6900
    VIRTIO_EMULATION_HOTPLUG_TRANS              False(0)
    VIRTIO_NET_EMULATION_ENABLE                 False(0)
    VIRTIO_NET_EMULATION_NUM_MSIX               2
    VIRTIO_NET_EMULATION_NUM_PF                 0
    VIRTIO_NET_EMULATION_NUM_VF                 0
    VIRTIO_NET_EMULATION_PF_PCI_LAYOUT          VIRTIO_1_X(0)
    VIRTIO_NET_EMULATION_SUBSYSTEM_ID           4161
    VIRTIO_NET_EMULATION_VF_PCI_LAYOUT          VIRTIO_1_X(0)
    VIRTIO_NET_EMU_SUBSYSTEM_VENDOR_ID          6900
    VL15_BUFFER_SIZE_P1                         0
    RPG_MIN_RATE_P2                             1
    RPG_THRESHOLD_P1                            1
    RPG_THRESHOLD_P2                            1
    SM_DISABLE                                  False(0)
    SRIOV_EN                                    False(0)
    UCTX_EN                                     True(1)
    UEFI_HII_EN                                 True(1)
    VF_LOG_BAR_SIZE                             1
    VL15_BUFFER_SIZE_P2                         0
    VL_BUFFER_ALLOCATION_P1                     FULL_DYNAMIC(1)
    VL_BUFFER_ALLOCATION_P2                     FULL_DYNAMIC(1)
    VL_ISOLATION_MODE_P1                        DEVICE_DEFAULT(0)
    VL_ISOLATION_MODE_P2                        DEVICE_DEFAULT(0)
    ZERO_TOUCH_TUNING_ENABLE                    False(0)
Please try setting the following mlxconfig parameters:
mlxconfig -d /dev/mst/mt41686_pciconf0 set HIDE_PORT2_PF=True
mlxconfig -d /dev/mst/mt41686_pciconf0 set KEEP_LINK_UP_ON_BOOT_P2=False
mlxconfig -d /dev/mst/mt41686_pciconf0 set KEEP_ETH_LINK_UP_P2=False
mlxconfig -d /dev/mst/mt41686_pciconf0 set AUTO_POWER_SAVE_LINK_DOWN_P2=True
Once done, please run mlxfwreset:
And then reboot the host.
Once the host starts up again, please check if the p2 interface still appears.
If the interface still appears, please open a support case directly and it will be handled based on entitlement.
Thanks,
Jonathan.
