POWER_BTN# active time
The document “Jetson TX2 OEM Product Design Guide” describes about POWER_BTN# active time on Table 7 Power Up Sequence Timing Relationships in page 11.
Minimum time of POWER_BTN# active time is 50ms, but Maximum time is not described.
Please tell me the max.time of POWER_BTN# active time.
I’d like to power on the TX2 by an external signal, but when the pulse is too long (about 7sec), system does not boot up.
Actually, I don’t use such a signal, but I want to know min.and max.of POWER_BTN# active time for reference.
Best Regards,
Hi nanoto,
Please refer to this topic: [url]How can I change the power down time of MAX77620? - Jetson TX1 - NVIDIA Developer Forums , it is same to TX1 or TX2.
Default max time is 8s.
Hi Trumany,
Thank you for your answer.
I see.
Best Regards,
