power jetson dev kit
Is there an alternative way of powering on the dev kit than the button?
Is there a pin exposed for power on / reset functions?
There is a 2-pin 0.1" spacing header on the dev carrier board which is in parallel to the power and reset buttons. One half of that is ground, shorting the other half to ground is the same as pressing the button.
