Hello everyone,
I can’t remember exactly what command I ran in the terminal, but I think I have a problem with the 1.8V.
I can see in the TX2 datasheet (below page 11) that this ‘System Power’ or more precise ‘Jetson TX2 System Power (Main 1.8V rail most IF pins are associated with)’ should power up before ‘CARRIER_PWR_ON’.
https://usermanual.wiki/Pdf/jetsontx2oemproductdesignguide.2134990230.pdf
Does anyone know what is this channel: ‘Jetson TX2 System Power (Main 1.8V rail most IF pins are associated with)’???
