I want to transfer a video data stream from an FPGA board to a Jetson Nano Devkit. I have made some changes in the the ‘imx219’ driver, so now my FPGA board is recognized as ‘/dev/video0’. When I try to capture a test frame using yavta, I get this output and the test frame is never captured.
Device /dev/video0 opened.
Device `vi-output, imx219 7-0010' on `platform:54080000.vi:0' (driver 'tegra-video') supports video, capture, without mplanes.
Video format set: YUYV (56595559) 128x128 (stride 256) field none buffer size 32768
Video format: YUYV (56595559) 128x128 (stride 256) field none buffer size 32768
8 buffers requested.
length: 32768 offset: 0 timestamp type/source: mono/EoF
Buffer 0/0 mapped at address 0x7f834f4000.
length: 32768 offset: 32768 timestamp type/source: mono/EoF
Buffer 1/0 mapped at address 0x7f834cc000.
length: 32768 offset: 65536 timestamp type/source: mono/EoF
Buffer 2/0 mapped at address 0x7f834c4000.
length: 32768 offset: 98304 timestamp type/source: mono/EoF
Buffer 3/0 mapped at address 0x7f834bc000.
length: 32768 offset: 131072 timestamp type/source: mono/EoF
Buffer 4/0 mapped at address 0x7f834b4000.
length: 32768 offset: 163840 timestamp type/source: mono/EoF
Buffer 5/0 mapped at address 0x7f8334f000.
length: 32768 offset: 196608 timestamp type/source: mono/EoF
Buffer 6/0 mapped at address 0x7f83347000.
length: 32768 offset: 229376 timestamp type/source: mono/EoF
Buffer 7/0 mapped at address 0x7f8333f000.
In the kernel outputs I get this error:
[ 33.282973] video4linux video0: frame start syncpt timeout!0
[ 33.491014] video4linux video0: frame start syncpt timeout!0
[ 33.699532] video4linux video0: frame start syncpt timeout!0
[ 33.907425] video4linux video0: frame start syncpt timeout!0
[ 34.122716] video4linux video0: frame start syncpt timeout!0
[ 34.338395] video4linux video0: frame start syncpt timeout!0
[ 34.554183] video4linux video0: frame start syncpt timeout!0
[ 34.769968] video4linux video0: frame start syncpt timeout!0
[ 34.985736] video4linux video0: frame start syncpt timeout!0
[ 35.200439] video4linux video0: frame start syncpt timeout!0
[ 35.415147] video4linux video0: frame start syncpt timeout!0
Also the contents of the trace file is as follows:
$ sudo cat /sys/kernel/debug/tracing/trace
yavta-8328 [003] .... 1984.071289: tegra_channel_open: vi-output, imx219 7-0010
yavta-8328 [000] .... 1984.075182: camera_common_s_power: status : 0x1
yavta-8328 [000] .... 1984.203159: camera_common_s_power: status : 0x0
yavta-8328 [000] .... 1984.203588: tegra_channel_set_power: imx219 7-0010 : 0x1
yavta-8328 [000] .... 1984.203711: camera_common_s_power: status : 0x1
yavta-8328 [000] .... 1984.227504: tegra_channel_set_power: nvcsi--2 : 0x1
yavta-8328 [000] .... 1984.227519: csi_s_power: enable : 0x1
vi-output, imx2-8329 [002] .... 1984.236610: tegra_channel_set_stream: enable : 0x1
vi-output, imx2-8329 [002] .... 1984.238630: tegra_channel_set_stream: nvcsi--2 : 0x1
vi-output, imx2-8329 [002] .... 1984.238632: csi_s_stream: enable : 0x1
vi-output, imx2-8329 [002] .... 1984.238652: tegra_channel_set_stream: imx219 7-0010 : 0x1
vi-output, imx2-8329 [000] .... 1984.476494: tegra_channel_capture_frame: sof:-270686159872.1
vi-output, imx2-8329 [000] .... 1984.684493: tegra_channel_capture_frame: sof:-270686171136.1
vi-output, imx2-8329 [000] .... 1984.892433: tegra_channel_capture_frame: sof:-270686173184.1
vi-output, imx2-8329 [000] .... 1985.100535: tegra_channel_capture_frame: sof:-270686175232.1
vi-output, imx2-8329 [000] .... 1985.308633: tegra_channel_capture_frame: sof:-270686174208.1
vi-output, imx2-8329 [000] .... 1985.516483: tegra_channel_capture_frame: sof:-270686161920.1
vi-output, imx2-8329 [000] .... 1985.724376: tegra_channel_capture_frame: sof:-270686163968.1
vi-output, imx2-8329 [000] .... 1985.932485: tegra_channel_capture_frame: sof:-270686166016.1
vi-output, imx2-8329 [001] .... 1986.140596: tegra_channel_capture_frame: sof:-270686159872.1
vi-output, imx2-8329 [001] .... 1986.348705: tegra_channel_capture_frame: sof:-270686171136.1
vi-output, imx2-8329 [003] .... 1986.556690: tegra_channel_capture_frame: sof:-270686173184.1
vi-output, imx2-8329 [003] .... 1986.764265: tegra_channel_capture_frame: sof:-270686175232.1
vi-output, imx2-8329 [003] .... 1986.972484: tegra_channel_capture_frame: sof:-270686174208.1
vi-output, imx2-8329 [003] .... 1987.180470: tegra_channel_capture_frame: sof:-270686161920.1
vi-output, imx2-8329 [003] .... 1987.388414: tegra_channel_capture_frame: sof:-270686163968.1
vi-output, imx2-8329 [003] .... 1987.596217: tegra_channel_capture_frame: sof:-270686166016.1
vi-output, imx2-8329 [003] .... 1987.804482: tegra_channel_capture_frame: sof:-270686159872.1
vi-output, imx2-8329 [003] .... 1988.012375: tegra_channel_capture_frame: sof:-270686171136.1
vi-output, imx2-8329 [003] .... 1988.220480: tegra_channel_capture_frame: sof:-270686173184.1
vi-output, imx2-8329 [003] .... 1988.427939: tegra_channel_capture_frame: sof:-270686175232.1
vi-output, imx2-8329 [003] .... 1988.636417: tegra_channel_capture_frame: sof:-270686174208.1
vi-output, imx2-8329 [003] .... 1988.844276: tegra_channel_capture_frame: sof:-270686161920.1
vi-output, imx2-8329 [003] .... 1989.052192: tegra_channel_capture_frame: sof:-270686163968.1
vi-output, imx2-8329 [003] .... 1989.260333: tegra_channel_capture_frame: sof:-270686166016.1
vi-output, imx2-8329 [003] .... 1989.468151: tegra_channel_capture_frame: sof:-270686159872.1
vi-output, imx2-8329 [003] .... 1989.676115: tegra_channel_capture_frame: sof:-270686171136.1
vi-output, imx2-8329 [003] .... 1989.884152: tegra_channel_capture_frame: sof:-270686173184.1
vi-output, imx2-8329 [003] .... 1990.092344: tegra_channel_capture_frame: sof:-270686175232.1
vi-output, imx2-8329 [003] .... 1990.300320: tegra_channel_capture_frame: sof:-270686174208.1
vi-output, imx2-8329 [003] .... 1990.508178: tegra_channel_capture_frame: sof:-270686161920.1
vi-output, imx2-8329 [003] .... 1990.715803: tegra_channel_capture_frame: sof:-270686163968.1
vi-output, imx2-8329 [003] .... 1990.924002: tegra_channel_capture_frame: sof:-270686166016.1
vi-output, imx2-8329 [003] .... 1991.132201: tegra_channel_capture_frame: sof:-270686159872.1
yavta-8328 [001] .... 1991.183926: tegra_channel_close: vi-output, imx219 7-0010
vi-output, imx2-8329 [003] .... 1991.340264: tegra_channel_capture_frame: sof:-270686171136.1
yavta-8328 [001] .... 1991.340505: tegra_channel_set_stream: enable : 0x0
yavta-8328 [001] .... 1991.340511: tegra_channel_set_stream: imx219 7-0010 : 0x0
yavta-8328 [000] .... 1991.392209: tegra_channel_set_stream: nvcsi--2 : 0x0
yavta-8328 [000] .... 1991.392226: csi_s_stream: enable : 0x0
yavta-8328 [000] .... 1991.400237: tegra_channel_set_power: imx219 7-0010 : 0x0
yavta-8328 [000] .... 1991.400358: camera_common_s_power: status : 0x0
yavta-8328 [000] .... 1991.400991: tegra_channel_set_power: nvcsi--2 : 0x0
yavta-8328 [000] .... 1991.400998: csi_s_power: enable : 0x0
I checked CSI signals in the oscilloscope and it seams that signal in both LP and HS modes has correct voltage levels. CSI configuration that I use has 2 lanes and the line rate is 90 Mbps.
I can not find out whether the problem is from the FPGA side or in the linux driver. I would appreciate if anyone can help me on this.
