During the installation of Cuda I met a problem.
I followed the installation on http: // doc.ubuntu-fr.org / cuda
I installed the toolkit and the sdk but once arrived at the test I have an error message:
/code
OpenGL device is Available
FATAL: Error inserting nvidia_331_updates_uvm (/lib/modules/3.8.0-39-generic/updates/dkms/nvidia-331-updates-uvm.ko): Unknown symbol in module, or unknown parameter (see dmesg)
fluidsGL.cpp(416) : CUDA Runtime API error 30: unknown error.
code/
SO Folks DONT SKIP THIS INPORTANT STEP!!!
It seem’s like others are also having this problem… I will cross post!!
Good Luck…
On the bright side this install (os and cuda) only took a day (85% being opensuse’s)!
This is far better then the cuda 5.5 which had to be done by manually shuting down the
graphics subsystem! That and fedora which trashed my drives took a month to set up!
But I have to say for those who are new… stick with it … It is well worth it!
Cuda will change how you solve computational problems… and for the better!
